Hello everyone, I've read a lot here in the forum, but haven't written anything yet. I find everything very professional and competent. Recently, I logged the boost pressure on my car (Sharan with DFLA engine). What do you think, is this graph (especially the right side of the image) normal? I haven't noticed anything unusual in the driving behavior, I just logged it spontaneously.
Around 2000 rpm, you'll notice a slight dip in the actual torque value. As long as your engine control unit (ECU) doesn't reduce the torque output during this dip, it's generally okay.
Okay, you're already easing off the throttle again, as you can see from the drop in the RPM curve (red). There's a slight overshoot here. Without significant turbocharger boost, the turbocharger pressure behavior isn't very well defined, but I still consider it normal. Possibly the variable turbine geometry (VTG) is already a bit stiff, but as long as there are no error messages...
Thank you for the answer and explanation. The drop in RPM likely occurred because the throttle was briefly closed, which is also visible in the RPM curve. Is there perhaps a forum thread where people post about the turbo boost behavior of different engines, or does that not make sense?
Thank you for the answer and explanation. The undershoot likely occurs because the throttle was briefly closed, which is also visible in the RPM curve. Is there perhaps a thread where people post about the turbo boost behavior of different engines, or does that not make sense?
There is no topic for this, and in my opinion, it is not necessary.
