[1.9 TDI] BKC Correction value for the running idle control
Avocado
Post16-02-2023, 20:07    Subject: [1.9 TDI] BKC Correction value for the running idle control Quote
Hello, does anyone happen to know the normal values / reference values for the correction factors of the cylinders?
The correction value for the 4-cylinder engine seems a bit high to me. But I can't find any data about it...
Warmest greetings
 File size:  180.34 KB
 Viewed:  391 times
Karma: +1359 / -0   Thank you, like it!
dieselschrauber likes this.
Post16-02-2023, 20:49    Subject: [1.9 TDI] BKC Correction value for the running idle control Quote
Completely normal.
Karma: +807 / -0   Thank you, like it!
Post16-02-2023, 21:50    Subject: [1.9 TDI] BKC Correction value for the running idle control Quote
The values are good.
No new posts Idling speed control 85kW PD /AJM Diesel Engine Technology
No new posts Log File Idle State: Full Reproduction Now Available. On-Board Diagnostics (OBD)
