LMM at TD4
mbrokof
Post24-02-2023, 14:24    Subject: LMM at TD4 Quote
Hello there!
"Although I don't currently own a VW or Audi, I still thought I would write. It seems this problem exists everywhere."
LMM
I'm looking for the wiring diagram for the mass airflow sensor (MAF) because I want to only connect the temperature sensor of the Bosch MAF to test how it affects driving and, especially, emissions values.
I found the information for some LMM in the article about the AGR, and also a picture of something that can be done, but I don't have a clear understanding yet. Is the temperature sensor in the MAF controlled separately, or is that not possible separately?
I have a Freelander 1 TD4 from 2002. I bought a cheap MAF sensor on eBay, and it improved the driving somewhat, but not as well as when there's no MAF sensor installed at all. I also have a new Bosch MAF sensor that I want to try, but first, I'd like to experiment with this one. I haven't been able to cut open the old MAF sensor yet to see its wiring, but somehow I feel that the airflow is being restricted too much.
VG
Matthias.
Translated on 15-07-2026, 1:56.
Karma: +805 / -0   Thank you, like it!
Post25-02-2023, 11:07    Subject: LMM at TD4 Quote
"Nothing is being controlled there; those are sensors. The engine control unit uses the temperature reading for correction purposes, and if it's reasonably accurate, it doesn't have a major influence."
The simplest solution is to use the right LLM.
Translated on 15-07-2026, 1:58.
mbrokof
Post25-03-2023, 16:51    Subject: LMM at TD4 Quote
Hello Rainer,
Danke fuer die Antwort und entschuldige die verspaetete Rueckmeldung. JA, den Bosch habe ich mittlerweile auch installiert, aber der Verbrauch wird immer hoeher, die Luftmessungen passen trotz allem nicht, wenn er abgezogen wird, ist's besser als mit. AGR neu oder gereinigt, PCV vor kurzem getauscht, Ansaugkruemmer sollte noch sauber genug sein. Ist nicht allzulange her, dass ich ihn gereinigt habe. It doesn't really make sense, unless the high-pressure pump is malfunctioning again.
VG
Matthias.
Translated on 15-07-2026, 1:59.
E30_V8 likes this.
Post25-03-2023, 18:50    Subject: LMM at TD4 Quote
You need a suitable OBD diagnostic tool and a structured approach to obtain meaningful results.
Currently: Speculations, lack of knowledge, guesswork...
mbrokof
Post26-03-2023, 17:26    Subject: LMM at TD4 Quote
Is this okay, or do you need more information?
Messungen - Copy.xlsx
 LMM at TD4
LMM at TD4
 File name:  Messungen - Copy.xlsx
 File size:  124.77 KB
 Downloaded:  237 times
Translated on 15-07-2026, 2:00.
Post26-03-2023, 17:30    Subject: LMM at TD4 Quote
No, that's great; you can use that to check your assumptions about the air mass.
mbrokof
Post07-04-2023, 10:41    Subject: Without MAF Quote
Okay, thank you.
It's strange that when the mass airflow sensor (MAF) is disconnected...
I'm getting significantly better air quality readings than I was before with the new Bosch part. I'm going to try replacing the rail pressure sensor. Recently, I found something where someone else had a similar problem and said that changing the sensor improved their readings. I had a Febi sensor installed, but it leaked because parts were missing, so the old one went back in.
lllll.log-live-1_1.4.23 - Copy.xlsx
 LMM at TD4
LMM at TD4
 File name:  lllll.log-live-1_1.4.23 - Copy.xlsx
 File size:  39.24 KB
 Downloaded:  193 times
kkkkk.log-live-1_29.03.2023 - Copy.xlsx
 LMM at TD4
LMM at TD4
 File name:  kkkkk.log-live-1_29.03.2023 - Copy.xlsx
 File size:  44.44 KB
 Downloaded:  223 times
mbrokof
Post11-04-2023, 15:04    Subject: An idea? Quote
Perhaps someone has an idea. I filled the tank completely on Saturday, then yesterday I installed the MAF sensor and in the afternoon, the new sensor. Now, after driving about 50 miles, I'm looking at the fuel gauge and it's already a quarter empty. There's nothing visible underneath the car, so I suspect it's related to the MAF sensor.
Two weeks ago, the fuel consumption was 12 liters per 100km when the mass airflow sensor (MAF) was connected. After disconnecting it, the consumption dropped to 8.5 and then to 7.6 liters per 100km, mostly in city traffic. The MAF sensor is new. I can't imagine that the sensor itself is faulty, so I will first disconnect the MAF again and test it. However, this will result in a fuel injection of -40 degrees Celsius.
The consumption shouldn't be this much lower. Also, it doesn't have any power anymore when that part is installed, and the automatic transmission is starting to jerk again. Is there no way to figure out which cable belongs to the temperature sensor?
Translated on 15-07-2026, 2:02.
Post11-04-2023, 15:30    Subject: LMM at TD4 Quote
You need a wiring diagram and a diagnostic tool. And with the support ticket, I will also explain what a motor control unit does. icon_idea.gif
Translated on 15-07-2026, 2:04.
mbrokof
Post14-04-2023, 8:56    Subject: Support ticket Quote
Yes, that idea also occurred to me after I wrote it. I'm already trying to figure out where the wires from the mass airflow sensor (MAF) connect to the control unit, and if that's something that can be addressed through a support ticket, then that's a good suggestion, thank you.
mbrokof
dieselschrauber likes this.
Post20-04-2023, 8:24    Subject: Input signal unplugged Quote
Hello Rainer,
ich habe das Eingangssignal rausgenommen und werde das erstmal testen und aufzeichnen, bevor ich das Supportticket aufmachen, ich nehme an fuer techn. Support.
Matthias.
Translated on 15-07-2026, 2:05.
mbrokof
Post30-04-2023, 16:31    Subject: Result Quote
Hi Rainer,
I disconnected the input signal and took some measurements. The results are similar to what I got before with no input, but I can't say for sure if it's set to -40 degrees. The manufacturer hasn't given me any feedback on how to check that. The power consumption is quite high. I'll continue testing.
Greetings.
Translated on 15-07-2026, 2:06.
