Is VCP compatible with ODIS?
philip.hoheneder
Post14-03-2024, 12:34    Subject: Is VCP compatible with ODIS? Quote
Hello Rainer,
Is it perhaps possible to create a foundation for ODIS using the VCP drivers? The original VAG interface costs approximately €1,500 currently. However, there are also "open" interfaces available that simply redirect the software. Are there any experiences with these?
Thank you very much in advance.
Philip.
Post14-03-2024, 12:51    Subject: Re: Is VCP compatible with ODIS? Quote
philip.hoheneder wrote:
Hello Rainer,
Philip
Hello Philipp,
J2534 compatibility was considered, but it appears that this is not being pursued at the moment.
VCP drivers: Drivers for "virtual COM ports" are only available for the outdated HEX-USB+CAN device. However, that wouldn't help either, as the J2534 system uses a completely different communication interface.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber likes this.
Post14-03-2024, 19:07    Subject: Is VCP compatible with ODIS? Quote
Hello Philipp,
I personally use a Mongoose Plus as a pass-through interface, and the VCI from the Megamacs 77.
Both work well with OEM software/testers. So far, I haven't been able to detect any significant differences.
Not even with other manufacturers.
That seems to fit.
Regarding BMW, I've noticed that there are differences in the flashing process. In that case, the Icom is significantly faster. But BMW also has Ethernet.
Michael.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Verwendung Einspritzdüsen TDI Diesel Engine Technology
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
No new posts TDI AFN: Mechanical ESP Possible? Diesel Engine Technology
No new posts Motorumbau möglich? Diesel Engine Technology
