Help, I can't get my Maix adapter to work
jensg
Post25-07-2003, 8:47    Subject: Help, I can't get my Maix adapter to work Quote
Hello Maik, and hello to all the other experts,
I received and connected Maik's adapter, but it's not working. The car is a G4 TDI 90PS with AGR. With the laptop (VAGCom 303 demo) and car connected, the green and red LEDs are lit. During the LED test, the yellow and the other red LED blink, and the message 'Com3 LED Test OK' appears. However, during the test, an error message 'Error 5: unknown device' is displayed.
What am I doing wrong?
There are two potentiometers icon_redface.gif that you can apparently turn, but it doesn't seem to do anything (is only one rotation relevant?, or can you turn them endlessly?). I'm not an electronics expert . Or is there a specific procedure ? By the way, while adjusting, the red and yellow LEDs flash briefly.
I've also followed the tip of testing without the car connected, and the result is the same (even though no LEDs are lit, the LED test is OK), but the 'unknown device' message persists.
P.S. As Maik described, I connected the ground wire to pin 5 (signal ground) of the connector. However, Rainer's post about the adapter refers to pin 4 (car ground).
Could it be because of that?
Maik
Post28-07-2003, 8:07    Subject: Subject: Re: Help, can't get my Maiks adapter working Quote
Hi, please send me your private email address and phone number. Then I'll give you a call.
Maik.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts DPF not regenerating Troubleshooting & Guides
No new posts VAGCOM Adapter: Questions and Answers Diesel Engine Technology
No new posts VAGCOM/OBD2: Optocoupler Adapter for Old 1Z Diesel Engine Technology
No new posts Question about Maik's VAGCOM interface Diesel Engine Technology
No new posts TDI in limp mode: Troubleshooting guide Diesel Engine Technology
