Disable tachograph
Killroy0815
Post16-09-2024, 10:02    Subject: Disable tachograph Quote
My question is: Can I simply disable the tachograph in the control panel slot, address 17? It's no longer needed because it's for private use. Is it a T5?
Jörg.
Post16-09-2024, 11:53    Subject: Disable tachograph Quote
Hello Jörg,
If possible, it might be achievable through coding.
What options do you have?
Killroy0815
Post17-09-2024, 10:07    Subject: Disable tachograph Quote
I have a HEX-USB+CAN interface and VCDS version 23.11.
I will have the bus here this weekend and then I will read the diagnostic data.
Regarding the coding, I need to subtract the number for the tachograph. I think I still remember that.
I had my A8 newly programmed back then because new parts were added.
Otherwise, I'll have to read it again.
Please send the scan afterwards.
Jörg.
No new posts T4 gelbes Dreieck vom Fahrtenschreiber ? On-Board Diagnostics (OBD)
No new posts Disable AGR? Diesel Engine Technology
No new posts Disable T4 WFS: How to & Troubleshooting On-Board Diagnostics (OBD)
No new posts Deactivate front passenger airbag Diesel Engine Technology
