Broken Motor Mount? Get a Fast Replacement!
Georg_G
2012 Volkswagen Golf
Post26-06-2003, 12:28    Subject: Broken Motor Mount? Get a Fast Replacement! Quote
The vehicle is a Seat Ibiza manufactured in the year 2000 with 60,000 kilometers on the odometer.
When I suddenly accelerate, there's a slight clicking sound coming from the area behind the center console.
The motor exhibits approximately 2 cm of play in its mounting when pressed firmly by hand in all directions.
Is that how it's supposed to be?
Or perhaps the engine mounts are worn out. The car was driven with a power box/turbocharger booster in some instances, resulting in significantly increased torque.
Thank you for your responses.
George.
Translated on 22-08-2026, 16:11.
Post26-06-2003, 13:56    Subject: Broken Motor Mount? Get a Fast Replacement! Quote
Do the drive shafts have any play? I would suspect them more. The motor should be able to move slightly; this is necessary for damping vibrations.
Translated on 22-08-2026, 16:12.
No new posts Engine Mounts: Types, Replacement & More Diesel Engine Technology
No new posts PDE Failure: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts AFN Cat Adapter Broken: Troubleshooting & Repair Diesel Engine Technology
No new posts TDI Passat: Faulty MAF Sensor & Head Gasket Diesel Engine Technology
