Boost pressure problems P0299 and limp mode
Heiner111
Karma: +27 / -0   Thank you, like it!
Post31-01-2026, 18:45    Subject: Boost pressure problems P0299 and limp mode Quote
Hello, I'm writing this in a similar way to the old topic that has already been closed (icon_smile.gif dieselschrauber.org/viewtopic.php?t=29644).
Here's a quick note for you, @Herbert. Yes, I know the post was very old. But my thought was that whoever saw it might (hopefully) receive an email about the topic and perhaps be prompted to share their experiences (okay, it didn't work). Since similar problems seem to occur from time to time, it was worth trying, and it could also help future readers.
Okay, I'd be happy to follow his recommendation and rewrite my observations here.
It's a 2.0 BRD model with approximately 307,000 km. For the past two weeks, it has intermittently entered "limp mode" on the highway at moderate speeds (100 to 120 km/h) while being driven gently. Most of the time, the following errors are displayed (abbreviated for clarity):
004705 - Valve for pump/nozzle, cylinder 1 (N240)
P1261 - 006 - Limit exceeded - Intermittent
Environmental conditions:
Error status: 00100001
Error frequency: 4
Speed: 2368 RPM.
Torque: 152.0 Nm
Speed: 114.0 km/h
76.05%
5.375 µF
14.00 mJ
11 mJ
Raw, Form. N/A: 000,000,000
000665 - Charge pressure control.
P0299 - 006 - Control limit exceeded - Intermittent.
Error status: 00000001
Error frequency: 1
Speed: 2240 RPM.
Torque: 336.0 Nm
Speed: 121.0 km/h
78.78%
Voltage: 14.24 V
Pressure: 2449.5 mbar
Pressure: 2002.2 mbar.
"Occasionally, I also get error code 0299 (charge pressure difference). When both errors occur, the PDE error always appears first. However, I can't currently see how the PDE error could be the cause of the LD error. I don't see any connection between the two, and I also believe that the PDE error should cause hesitation." I only saw one post online with this combination of symptoms, and it didn't have a clear diagnosis.
Overall, it's running pretty well; the performance is quite okay (but I don't have anything to compare it to). You only notice the start of the emergency running mode by the indicator light; there's no jerking or anything like that. So, I've now logged the pressure readings over two trips. "Outbound" trip: started cold, then a few minutes in the city, followed by 12 km on the highway. It went into emergency running mode after about 5 minutes. The rest was city driving for 3 minutes. "Return" trip: the same in reverse, and no emergency running mode occurred. When I look at the logged pressure curves for the target and actual boost pressure, I can see that the pressure generally doesn't reach the target (but the graph isn't cropped at any point). However, during the drive there, it becomes apparent that both things are actually running parallel (albeit at a low level) later on in the city.
I could imagine that...
- The turbocharger pressure control is malfunctioning. I replaced the valve about 4 years ago (with a Pierburg brand part). So it's less likely, but still possible. Visual inspection of UD (Ultra-High Molecular Weight Polyethylene) tubes revealed no abnormalities.
- Turbocharger boost pressure leak, visual inspections have not yet revealed the cause.
- The vertical travel gauge may be stuck; unfortunately, the linkage on the BRD is so hidden that it's impossible to see or reach, even without disassembly. I'll have to check it when the weather is better. But it seems to be moving somewhat (city driving) - and if I test it, then definitely icon_sad.gif.
The DPF (Diesel Particulate Filter) could also be a problem, but in my opinion, the symptoms don't seem to fit.
I'm going to inspect the vacuum hoses more closely, section by section, and then run the loading line under steam. But I don't think there will be anything wrong. It will take some time (weather https://community.).
Before I proceed, I would appreciate some input. Those with relevant experience regarding this issue will likely be able to rule out certain possibilities based on the descriptions, such as DFP (likely referring to a specific component), vacuum control valve, leaks, etc. I assume that the behavior will exhibit different characteristics depending on the underlying cause. And maybe someone knows of a connection between the two errors.
If anyone has any other tips, please share them! I'm grateful for any suggestions.
Rückfahrt 30Jan.pdf
 File name:  Rückfahrt 30Jan.pdf
 File size:  126.16 KB
 Downloaded:  142 times
Hinfahrt 30Jan.pdf
 File name:  Hinfahrt 30Jan.pdf
 File size:  125.42 KB
 Downloaded:  145 times
Translated on 03-07-2026, 22:15.
Post01-02-2026, 13:11    Subject: Boost pressure problems P0299 and limp mode Quote
Hi, I'm raising the question: What differences and what temporal sequence can you identify in the boost/reduction of boost pressure in the attached PDF files?
Please think about it.
The error seems to me like a typical, occasional hang-up of the VTG (variable geometry turbocharger) due to worn or carbon-fouled AGR (exhaust gas recirculation) components.
For completeness, I would check the ventilation of the vacuum system and, using a VTG actuator test, verify whether the VTG returns to its normal position quickly enough.
Translated on 03-07-2026, 22:22.
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost pressure control exceeded 3.0 bar, P0299 code / rou... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CBBB Error Code: Troubleshooting & Solutions Diesel Engine Technology
No new posts TDI Boost Problems: Troubleshooting Guide Diesel Engine Technology
No new posts 1.9 TDI BPX Turbo Problems & Solutions Diesel Engine Technology
No new posts Boost Issues: Troubleshooting with Logs On-Board Diagnostics (OBD)
