Development of the 1.9 l TDI Engine (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Articles
Herbert Post22-06-2011, 18:19
Here's an older article from the "Motortechnische Zeitschrift" that very interestingly describes the development steps leading to the 1.9-liter TDI engine with VP:
For example, it describes (so that the search function can find icon_wink.gif ):
- Construction data 1.9 TDI,
- Engine Management EDC, Engine Control Unit;
- Spritz start control, with charge pressure control and height adjustment;
- Combustion chamber optimization, design of piston groove and swirler channel;
- Interpretation of the crank housing, crank shaft, bevel gear mounting, vibration damper;
- Explanation of the timing belt drive;
- Emission characteristics.
A topic frequently discussed in the forum is the loosely mounted KW (suspension strut) mounting (loosening of the KW central screw and the KW strut extending). In this article, you will find the reason for the chosen construction method - this way, the KW cap for the TDI engine has been made durable.
Springer Automotive Media has kindly allowed us to publish this here in the forum. We would like to thank them again for this!
Ein neuer Turbodieselmotor mit DI.pdf
 Entwicklung des 1,9 l TDI Motors, Motormanagement, Kennfelder, Emissionen.
 File name:  Ein neuer Turbodieselmotor mit DI.pdf
 File size:  2.77 MB
 Downloaded:  5005 times
Ratings - Development of the 1.9 l TDI Engine
Average rating: 4.67 - worst rating: 4 - best rating: 5 - number of ratings: 3 - View ratings
No new posts EDC 15, ME7, ME9: Development and Tuning On-Board Diagnostics (OBD)
No new posts AFB Motor Suction Nozzle On-Board Diagnostics (OBD)
No new posts Engine Noise When Shutting Off Diesel Engine Technology
No new posts VW 1Z Engine ESP Tax Signal (VP37) On-Board Diagnostics (OBD)
