Worn Clutch? Get Clutch Replacement Now!
verdiener
Post05-07-2003, 10:03    Subject: Worn Clutch? Get Clutch Replacement Now! Quote
'I drive a 1997 Passat 3B2 with an AFN engine (81kW TDI). For about 20,000 km, I've noticed that the engagement point of my clutch is quite far forward (i.e., closer to the driver). This means it engages very late in the pedal travel. Sometimes, it even feels like the clutch engages a millisecond after I've completely released the pedal when shifting from first to second gear. Also, the clutch pedal is extremely heavy to operate. In stop-and-go traffic, it can be exhausting and even make your leg tired.'
Are these signs of a worn clutch? How can you visually identify a worn clutch?
(I don't want to wait until it completely fails, meaning until the sudden increase in speed and loss of acceleration. I want to have it replaced proactively, before it reaches that point.)
########## EDIT ##########
Okay, my car now has 197,000 kilometers on the odometer. I bought it used with 156,000 kilometers, and I don't know if it has had one or more clutch replacements. However, it was often driven with a trailer attached (which is why the rear shock absorbers wore out prematurely).
Translated on 06-09-2026, 7:51.
Post05-07-2003, 14:21    Subject: Worn Clutch? Get Clutch Replacement Now! Quote
Hi.
Eventually, every clutch will wear out, but without knowing the total mileage, it's practically impossible to give a reliable answer.
Then, of course, there are also "talented clutch drivers" who can wear out a clutch x times faster than an average driver icon_twisted.gif.
It's not entirely impossible that there are hydraulic problems between the pedal and the clutch. However, that's not my area of expertise, and other specialists might be able to provide more information.
Translated on 06-09-2026, 7:53.
christians
Post06-07-2003, 21:23    Subject: Worn Clutch? Get Clutch Replacement Now! Quote
"Late engagement with high force: This is the classic diagnosis. The clutch is nearing the end of its lifespan. How much longer it will last depends on the driving style. I don't know if there's a measurable wear limit, but it would be difficult to measure, especially since the characteristics of the diaphragm spring mean that as the friction lining thickness decreases, the friction decreases quite abruptly."
Gruß Christian
Translated on 06-09-2026, 7:54.
Uli S.
Post07-07-2003, 15:20    Subject: Worn Clutch? Get Clutch Replacement Now! Quote
Your Passat likely has a hydraulic clutch actuation system, and it usually adjusts itself automatically, so your problem probably doesn't indicate worn linings, but rather a malfunctioning adjustment mechanism. In a brake system, I would say the bleed hole in the master cylinder is clogged. So, you might want to disassemble and clean the slave cylinder icon_cry.gif. But that's easier than replacing the clutch...
Best regards, Uli.
Translated on 06-09-2026, 7:55.
olli
Karma: +46 / -0   Thank you, like it!
Post09-07-2003, 0:17    Subject: Worn Clutch? Get Clutch Replacement Now! Quote
Even a hydraulic clutch actuation system with automatic adjustment cannot compensate for anything if the lining is worn out icon_smile.gif.
The symptoms clearly indicate a worn-out clutch.
In theory, the release bearing could also be seized. I experienced something similar about 20 years ago with a Passat; even with a nearly new clutch, the diaphragm spring couldn't quite push the pedal back up. The cause back then was the salty roads leading to and from Berlin, which caused the clutch lever, including the shaft, to become quite free at the transmission.
For the sealed TDI engines, it would probably be necessary to regularly and specifically clean the engine to prevent issues.
Olli.
Translated on 06-09-2026, 7:56.
MarioS
Post09-07-2003, 11:31    Subject: Worn Clutch? Get Clutch Replacement Now! Quote
I still have a complete clutch kit from an A4 AFN.
If you're interested, feel free to reach out.
Bye Mario.
Translated on 06-09-2026, 7:57.
No new posts Worn clutch disc pressure plate bearing, Golf/Bora 85KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Replacement: Nissan Almera N16 Diesel Engine Technology
No new posts Clutch Worn Out After 14,000 km? Diesel Engine Technology
No new posts Worn synchronizer rings? Diesel Engine Technology
No new posts Passat NW worn out Diesel Engine Technology
