| Subject: Extending Diesel Filter Replacement Interval | |
| ulf |
A tip from forum member garth.brooks
Install a cost-effective line filter from the accessories trade in the inlet line from the tank to the filter. It catches larger dirt from the tank, so that the expensive This significantly reduces the clogging of the main filter, so that it can, with some luck, remain in use for several times the usual intervals in the vehicle. In case of doubt, when selecting a filter for a 8mm inner diameter hose, choose the largest size to achieve the greatest filter surface area, resulting in minimal pressure loss and longer filter lifespan. Clear or semi-transparent enclosures make it easier to see how much dirt the filter has collected and when it needs to be replaced. Translated on 03-07-2026, 14:19. |
| Ratings - Subject: Extending Diesel Filter Replacement Interval | |
Average rating: 4.00 - worst rating: 3 - best rating: 5 - number of ratings: 9 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.123s
