Cruise Control for VW Passat
edgar-s
Post22-07-2003, 8:44    Subject: Cruise Control for VW Passat Quote
I think it might be possible to replace the currently available aftermarket upgrades with a simple button. I would like to try this, but I'm missing the wiring diagram. Does anyone know which contacts on the activation button on the turn signal lever are connected?
Greetings...
Edgar
Translated on 16-10-2026, 16:47.
Post22-07-2003, 9:06    Subject: Cruise Control for VW Passat Quote
Hello Edgar,
Depending on the vehicle, the switches may be slightly different.
It's best to obtain a wiring diagram for the engine control unit and the corresponding repair manual for your specific vehicle.
You can then use a diagnostic device to test which pins lead to the desired bit combination.
If you permanently disable the GRA (Graphics Processing Accelerator) and only place the "Set" button somewhere as a physical button, I think that's a good and cost-effective solution.
Translated on 16-10-2026, 16:48.
edgar-s
Post25-07-2003, 19:59    Subject: Cruise Control for VW Passat Quote
[HI,
Okay, so those are my problems then. I just have the idea, but not the wiring diagram or anything like that. Where can I find something like that?
Edgar.
Translated on 16-10-2026, 16:49.
Sound Lupo 3L
Post25-07-2003, 20:32    Subject: Cruise Control for VW Passat Quote
hi,
If you can provide the exact year of manufacture, engine code, and preferably the transmission code, I might be able to figure it out.
greetings
Diesel-Dirk
Post26-07-2003, 9:18    Subject: Cruise Control for VW Passat Quote
Check out my website. In the automotive section, you'll find GRA wiring diagrams.
Translated on 16-10-2026, 16:50.
No new posts Cruise Control: Set Minimum Speed On-Board Diagnostics (OBD)
