Clutch and Flywheel: Repair & Replacement
TDIMANU
Post22-10-2004, 20:43    Subject: Clutch and Flywheel: Repair & Replacement Quote
Hab meinen AFN ein wenig auf die Sprünge geholfen! Nun will ich morgen ne Sachs Sportkupplung einbauen! Da ich auch noch ein Abgedrehtes, erleichtertes und gewuchtetes Schwungrad da habe wollte ich fragen ob es gut ist das zu verbauen? Vorteile? Drehfreudigkeit? Nachteile? Restless running?
What do you think? Who would drive something like that? Can anyone recommend it to me?
Manu.
Translated on 12-09-2026, 10:31.
Julian
Post22-10-2004, 20:51    Subject: Clutch and Flywheel: Problems and Solutions Quote
Vorteile? Drehfreudigkeit? YES.
Nachteile? Unruhiger lauf? YES.
Translated on 12-09-2026, 10:32.
vr6-tdi
Post22-10-2004, 20:59    Subject: Precision Flywheel: Balanced & High-Performance Quote
I had a lighter and more finely balanced flywheel in my GTI.
'Advantages: Significantly improved responsiveness - gets up to speed much faster!!'
Disadvantages: After prolonged and extreme use, it started to slip (BERGRENNEN - likely referring to a slipping or peeling issue).
and reduced engine braking effect!
The most important thing in such an action is the fine balancing of the modified swing, otherwise you could damage the crankshaft, etc. icon_rolleyes.gif
Translated on 12-09-2026, 10:33.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Flywheel: Replacement & Performance Diesel Engine Technology
No new posts Flywheel from ASZ Upload
No new posts AEL: New Flywheel - Improved Performance Diesel Engine Technology
No new posts Passat TDI Flywheel: AFN Engine, 1998 Model. Diesel Engine Technology
