Fuel Injector Tuning: Performance & Optimization
kossmann
2016 Audi Q3
Post14-09-2003, 18:28    Subject: Fuel Injector Tuning: Performance & Optimization Quote
Hello everyone,
I've been reading quite a bit about "larger" injectors recently and I'm curious. I have a 1Z model from 03/94 that doesn't run as smoothly as it used to. Furthermore, it's affected by the well-known needle lift valve issue.
There are now several price ranges mentioned... I've read almost everything, ranging from 180 to 1000 euros... it's likely that sometimes the prices refer only to the nozzles, while other times they include complete "sets" with brackets and other small parts.
Due to cost considerations, I have always refrained from replacing the needle lift sensor, as I can tolerate the severe jolting that occurs every 300-500 km (I hope the engine can handle it too).
However, it seems possible to extract a bit more power from the 66kW engine by using different nozzles, so if that's even a possibility, I would also replace the NHG (presumably a component).
- Can you install "larger" injectors in the 1Z engine without needing to tune the chip?
- What are the minimum costs to expect, and what is the cost of a complete replacement with a new heat generator (NHG)?
What are your general thoughts on the idea? The comments I've read so far mostly refer to the other engines (A...).
Translated on 23-10-2026, 21:03.
Albrecht
Post15-09-2003, 10:26    Subject: Fuel Injector Tuning: Performance & Optimization Quote
Hello Tino,
For your 1Z engine, the slightly larger injectors from the AFN engine (110 hp) would be a suitable option.
However, based on my own experience, I would recommend, if possible, to first test these nozzles (e.g., used ones) and then decide whether to use them.
The opinions regarding the properties seem to vary from person to person. In any case, I wasn't satisfied and reinstalled my original nozzles.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 23-10-2026, 21:05.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts 10Cent Tuning Technical Articles
No new posts Good tuning, bad tuning? Diesel Engine Technology
No new posts ASV Injectors for ALH Engines Diesel Engine Technology
No new posts Fuel Injectors AKN - Buy Now! On-Board Diagnostics (OBD)
No new posts Fuel Injectors: Types, Function & Replacement Upload
