Cable Glands: Blank Cables for Both Door Panels!
markuskxy
Post21-09-2003, 20:52    Subject: Cable Glands: Blank Cables for Both Door Panels! Quote
HELLO!
'I've been having this problem for three years now: the fuse for the window lifters keeps blowing at different intervals!'
Recently, the fuse has been blowing immediately.
OH YEAH, THE SAME GOES FOR THE REAR WINDOW HEATER.
When locking or unlocking, I could always open and close all the windows without any problems!
'THEN I THOUGHT, IT MUST BE A PROBLEM WITH THE WIRING!'
OF COURSE, I FIRST CHECKED THE DOOR AND THE REARVIEW MIRRORS, COMPLETELY UNWITTINGLY.
Standing in the doorway, I noticed the black, flexible cable duct, which was slightly bent in the middle.
I loosened the screws on both sides, pushed it to the side, and there I saw some white cables.
I noticed the same thing on the passenger-side door.
NEXT WEEK I WILL CHECK ALL THE DOORS AND THE TRUNK, AND I WILL INSULATE ANY EXPOSED WIRES WITH ELECTRICAL TAPE!
I will let you know if the fix works.
Best regards.
MARKUS
Translated on 05-08-2026, 6:39.
Mirko
Post21-09-2003, 20:59    Subject: Cable Glands: Blank Cables for Both Door Panels! Quote
Hi there,
but remember that they also need to remain flexible.
You won't achieve that with just a simple plastic strap.
By the way, this is an old problem, especially with SGAs (Specialized Genetic Assessments).
Am besten hilft immer noch das Erneuern unter Verwendung von noch . flex. Veins.
Have fun!
Mirko.
Translated on 05-08-2026, 6:42.
ManicMechanic
Post21-09-2003, 21:35    Subject: Cable Glands: Blank Cables for Both Door Panels! Quote
Hi!
@MarkusXY STOP YELLING!
Is it rude...?
Does writing everything in uppercase not hinder readability?
Frank.
Translated on 05-08-2026, 6:43.
markuskxy
Post28-09-2003, 21:44    Subject: Cable Glands: Blank Cables for Both Door Panels! Quote
The fuse is holding.
I temporarily insulated it with electrical tape.
Sorry for the capitalization!
Markus.
No new posts VAGCOM Adapter: From Old Cable to New Use Diesel Engine Technology
