A3 Doku: MKB ASZ Noise During Operation (Solution)
Michael II
Post30-09-2003, 9:28    Subject: A3 Doku: MKB ASZ Noise During Operation Quote
Whining noises in the transmission are audible in all gears at speeds below 1600 RPM and less than 60 km/h. These noises are temperature-dependent and become more pronounced as the transmission gets warmer.
Cause:
The meshing noises from the synchronizer are transmitted outwards through the left driveshaft, which is designed as a hollow shaft with a diameter of 42 mm.
Solution:
By installing a new left driveshaft (which is manufactured as a solid shaft with a diameter of 26 mm).
Part number 1J0 407 271 FD, can this issue be resolved?
Tschüss
Michael II
Translated on 18-09-2026, 17:11.
Ratings - A3 Doku: MKB ASZ Noise During Operation
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts VW Onboard Network Management: Documentation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB, AHW, AKQ, APE: Documenting Clicking Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Docs: Idle Vibration Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Deviation in 2.5 TDI BDG Operation On-Board Diagnostics (OBD)
No new posts Load Stress in Idle: Is It Meaningless? Diesel Engine Technology
No new posts Engine Jerk During Acceleration: Causes & Fixes Diesel Engine Technology
No new posts Erratic behavior in low-speed operation - is the to blame? Diesel Engine Technology
