VAG-Com Adapter: Full Version, No Reset Mode
gaspedaluser
Post30-09-2003, 21:23    Subject: VAG-Com Adapter: Full Version, No Reset Mode Quote
'I soldered the 2.4 adapter here from this forum some time ago. It worked quite well with my VAG-COM and my car (Passat 35i).'
Following that, I have now unlocked the full version 301.1 to upgrade the GRA (presumably referring to a specific feature or component) and other things.
This unlocking process worked perfectly.
However, I am unable to access the basic settings mode (04) in the engine control unit!
There are no error messages or anything like that. The preheating light is not flashing.
What could be the reason for that?
Thank you and greetings.
Gas pedal.
Translated on 14-10-2026, 23:45.
Post01-10-2003, 17:21    Subject: VAG-Com Adapter: Full Version, No Reset Needed Quote
There is no error message or anything like that. The preheating light is not blinking.
If all other functions are working smoothly (meaning the connection between the PC, adapter, and vehicle is stable), then there's likely a problem with the unlocking process -> you should complain to the software provider!
Translated on 14-10-2026, 23:46.
joergs
Post01-10-2003, 17:33    Subject: VAG-Com Adapter: Full Version, No Reset Mode Quote
it looks more like a software salesperson! icon_cool.gif If it's not a software sales issue, complain to the relevant department!
Translated on 14-10-2026, 23:47.
gaspedaluser
Post01-10-2003, 17:55    Subject: VAG-Com Adapter: Full Version, No Reset Mode Quote
Hello Ulf and Jörg,
it looks more like a software enthusiast!
If I contact Ross-Tech, the first question they will ask is what kind of adapter I have. They will definitely blame it on the homemade adapter. icon_cry.gif
So, what else could it be if VAG-COM is reading everything correctly?
As I mentioned, unlocking the GRA was not a problem.
Translated on 14-10-2026, 23:48.
Uwe@Ross-Tech
Post01-10-2003, 19:29    Subject: VAG-Com Adapter: Full Version, No Reset Mode Quote
No, the first questions in this case would be:
* Is the activation real, or was it generated by some kind of 'hack'? icon_smile.gif
Which version of VAG-COM is being used?
* What exactly happens when you click the 'reset to default' button?
-Uwe- VAG-COM Author
Translated on 14-10-2026, 23:49.
gaspedaluser
Post02-10-2003, 10:13    Subject: VAG-Com Adapter: Full Version, No Reset Mode Quote
Hello Mr. Ross,
Version 301.1 is at the top!
nothing, no error messages from the computer, no crashes, no access denied!
Greetings.
Translated on 14-10-2026, 23:50.
Uwe@Ross-Tech
Post02-10-2003, 14:27    Subject: VAG-Com Adapter: Full Version, No Reset Mode Quote
If the activation is not working properly, then something has gone wrong. In this case, please send me an email with your full name and other details (where you obtained the activation, invoice number or license number), and we will definitely resolve the issue.
However, if the unlocking was achieved through a hack, they have no grounds for a lawsuit. The 'default settings' function is only available in the full version.
-Uwe-
Translated on 14-10-2026, 23:52.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM Demo to Full Version Upgrade Diesel Engine Technology
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts USB K-Line Adapter: Buy Now! Diesel Engine Technology
No new posts Adapter Diesel Engine Technology
