Gremlin Guest
07-10-2003, 13:12 Subject: Off-Topic: mobile.dieselmechanics.de |
Hi there,
I just discovered the mobile link and tried it out on my M100 device:
It works perfectly. Therefore, you can also find solutions to problems while on the go  .
@rainer
Is there still a possibility to include a feature for writing posts? It's not essential, but it would be a nice addition. Palm and phone are always with me  .
CU Gremlin.
Translated on 14-07-2026, 15:50.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
07-10-2003, 13:21 Subject: Off-Topic: mobile.dieselmechanics.de |
Quote: | Is there still a possibility to implement a feature for writing posts? It's not crucial, but it would be a nice addition. I always have my phone and Palm device with me  | .
Is it planned?
Translated on 14-07-2026, 15:51.
Profile PM WWW Garage |
Gremlin Guest
07-10-2003, 13:26 Subject: Off-Topic: mobile.dieselmechanics.de |
and, just noticed:
the SEARCH FUNCTION is missing
CU Gremlin.
Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
08-10-2003, 8:28 Subject: Off-Topic: mobile.dieselmechanics.de |
Hello Gremlin!
Since I have a Palm m100 gathering dust at home, using it for this purpose seems like a logical option. Could you please provide me with a link so I can find out more about it?
A serial cable for the Palm is available; I just need the software.
Thank you very much, Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 14-07-2026, 15:52.
Profile PM Email Garage |
Marco Guest
08-10-2003, 10:22 Subject: Off-Topic: mobile.dieselmechanics.de |
Hi there,
'I have to chime in here as well. I often receive the 'Internal Server Gateway error' message on my phone. This only happens when viewing certain articles, such as those in the 10C section. The other forums work fine. Does anyone have any ideas about this?'
Translated on 14-07-2026, 15:53.
Marco Guest
08-10-2003, 10:24 Subject: Off-Topic: mobile.dieselmechanics.de |
and, just noticed:
CU Gremlin
Hello Gremlin,
You don't have to want everything right away!
Translated on 14-07-2026, 15:54.
08-10-2003, 11:47 Subject: Off-Topic: mobile.dieselmechanics.de |
The search function is included  .
Gremlin Guest
08-10-2003, 19:53 Subject: Off-Topic: mobile.dieselmechanics.de |
@marco
It might be due to the images in the posts. Not every phone and not every provider gateway or proxy can correctly render the pages.
@mc-giver
First, you need a suitable browser. I use Blazer from Handspring (http://www.handspring.com/software/blazer_overview.jhtml). which runs on its own proxy service and is therefore capable of displaying graphics. It can manage cookies and execute simple JavaScripts. Furthermore, it can access the internet through an upstream proxy server (e.g., a corporate proxy). This makes sense if you are connected to the regular computer via cable and want to configure the basic settings.
Normally, communication with a mobile phone works via infrared. If the phone has a built-in modem (which all current phones should have), then there's no problem. The phone is simply accessed as a modem, and that's it. I use an old Siemens S25 for this.
Connect through the service provider you trust the least.
If you use a null modem adapter, you can connect the M100's hot-sync cable directly to a modem (the M100 has the RS232 drivers built in). It's quite something when the modem is three times the size of the device itself...
If you want to connect your Palm device to the network via a PC (for setup and testing), you need Mocha-PPP (www.mochasoft.dk). This program creates an interface between the COM port (and thus, the Palm) and the TCP stack. This effectively connects the Palm to the TCP/IP network, making it believe that it is directly connected to the internet.
Any more questions?
CU Gremlin.
Translated on 14-07-2026, 15:56.
09-10-2003, 8:10 Subject: Off-Topic: mobile.dieselmechanics.de |
Hi Marco,
Quote: | | "Internal Server Gateway error". |
I am innocent. Occasionally, I get the error message "phpBB cannot connect to the database." This usually means that Hosteurope has had a cable come loose from their switch again.
Translated on 14-07-2026, 15:58.
