| Target values for 6-cylinder engines. VP AYM | |
| dieselschrauber |
Thank you to Sulzi for the following values!
group000 idle RPM 30-36. einspritzbegin 51-88 gas pedal 0 injection volume 10-30 "Ladedruck" - "boost pressure" - "no target value". Ambient air pressure: no setpoint value. Coolant temperature: 80-45. If greater than 80, allow the engine to warm up. intake air temperature, no target value. Fuel temperature: no target value. Air intake mass: 50-70. group000 full throttle RPM 140-170. injection start >115 gas pedal 255 injection volume 113-127 ladedruck 187-215 Ambient air pressure: no setpoint value. Coolant temperature: 80-45. If greater than 80, allow the engine to warm up. intake air temperature, no target value. Fuel temperature: no target value. intake air mass >185 If someone could please add that information to the property values. Sure, here's the translation: "Hi Sulzi" Translated on 07-07-2026, 3:27. |
| Ratings - Target values for 6-cylinder engines. VP AYM | |
Average rating: 0.00 - worst rating: 0 - best rating: 0 - number of ratings: 0 - View ratings |
You cannot post new topics in this forum. |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.096s
