Coolant Temperature Sensor Passat 35i - Specs
pausanias
Post11-10-2003, 19:55    Subject: Coolant Temperature Sensor Passat 35i - Specs Quote
'I have a Passat TD 35i, manufactured in 1992. My problem is that the temperature gauge shows much too low a reading. Since both the sensor and the gauge are working, I would like to know the technical data of the system. The sensor has a resistance of approximately 1400 ohms at 12 degrees Celsius, and about 300 ohms when the engine is warm. Is that okay? The temperature gauge shows 70 degrees at a resistance of 100 ohms, and 105 degrees at a resistance of 65 ohms. Does anyone know more?'
Furthermore, the fuel gauge is showing a reading that is much too high (but it's not due to the voltage stabilizer, as it's providing approximately 10 volts).
Translated on 01-10-2026, 1:32.
joergs
Post11-10-2003, 21:06    Subject: Coolant Temperature Sensor Passat 35i - Specs Quote
60 degrees: 600-700 ohms.
70 degrees: 400-500 ohms.
80 degrees: 290-380 ohms.
Translated on 01-10-2026, 1:33.
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW 1.6 TDI CR Specs: New Model Technical Data Diesel Engine Technology
No new posts Technical specifications ARL engine, 150 hp Diesel Engine Technology
No new posts Coolant Temperature Sensor Diesel Engine Technology
No new posts Coolant temperature sensor Audi 100 C4 AAT Diesel Engine Technology
