Injection start TDI AFN 81 kW
hturborbo01
Post20-10-2003, 18:13    Subject: Injection start TDI AFN 81 kW Quote
Hello everyone,
Does anyone know the exact regulations regarding...?
Injection start?
Is there any room for adjustment (tolerance)?
When does the injection start?
Since the entire process is subject to regulations, the mechanical...
The pre-emptive action was rendered null and void by the regulation.
I read in this forum that someone was talking about a slightly earlier...
Starting the injection earlier provides more bite.
The car needs to go for its inspection on Saturday. Since I have a...
Can I use the VW diagnostic tool to access the ESP (Electronic Stability Program) data?
towards early (while adhering to Volkswagen's specifications and tolerances).
advance.
Can anyone give me some advice?
'P.S. I currently have a tuning module from D-Chip installed.'
Power: 94 kW.
Actually, the pre-production version should benefit the tuning process somewhat.
Are you coming or what?
Please do not suggest any makeshift solutions. I am looking for a solution.
that does not result in the cancellation of the vehicle's approval certificate (ABE).
Hturbo01
Albrecht
Post20-10-2003, 18:25    Subject: Injection start TDI AFN 81 kW Quote
A mechanical advance of the pump within the specified tolerance range makes absolutely no difference, as the injection start is controlled. Slightly better starting.
One option would be to schedule it for an earlier time slot through adaptation – use the search function!
However, it doesn't really achieve much besides putting extra strain on the engine.
More power still primarily comes from more fuel.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
hturborbo01
Post24-10-2003, 21:12    Subject: Injection start TDI AFN 81 kW Quote
I'm somehow stuck on this question.
continue.
In the previous posts, I also couldn't find any.
find a satisfactory answer.
Tough luck.
Post25-10-2003, 7:31    Subject: Injection start TDI AFN 81 kW Quote
hturborbo01 wrote:
I'm somehow not getting this question.
continue.
Have you ever looked into the technical article section regarding the VP 37 setting?
No new posts Injection Start: Timing & Optimization Diesel Engine Technology
No new posts Fuel Injection Timing Off? Diesel Engine Technology
No new posts TDI V6: Dynamic Injection Timing AKN Diesel Engine Technology
No new posts Adjusting the fuel injection start with VAG-COM? On-Board Diagnostics (OBD)
