Quote: |
| Is it possible that a difference of 10° air temperature can increase the air density to such an extent that there is enough oxygen to completely compensate for soot formation? |
Yes, that's possible. If it barely makes it through the winter, there might be a small amount of fuel left over in the summer that doesn't have enough oxygen for combustion.
It could also be due to the fuel. Winter diesel often has a slightly higher fuel consumption, which means it contains a bit less energy (and oxidizing agents) per unit volume. This is also related to the topic of the MFA fuel consumption display.
