Temperature Display as LDA? Misuse?
eike
Post06-11-2003, 11:03    Subject: Temperature Display as LDA? Misuse? Quote
Hi everyone,
As I was sitting in the car during my lunch break, eating my sandwich (an interesting rhyme icon_rolleyes.gif), I had the idea to repurpose the temperature gauge as a boost pressure gauge. The scale already fits quite well. 90°C corresponds to 0.9 bar of boost pressure, and 130°C corresponds to 1.3 bar of boost pressure (the rest is analogous to that). In the newer models, the scale is even quite linear.
I've read several times here that the temperature display is controlled by the engine control unit (ECU) and not directly by the temperature sensors. The question now is, what format is the signal from the ECU to the display?
If it's an analog signal, it should be relatively simple to adjust the analog signal from the boost pressure sensor so that it can be used for the display instead of the 'temperature voltage.'
A small switch then handles the switching between temperature and boost pressure.
What is your opinion on that?
Greetings.
Eike.
Translated on 26-08-2026, 16:16.
garth.brooks
Post06-11-2003, 11:31    Subject: Boost Pressure Gauge: Accurate & Reliable Quote
Hi Eike,
Do you know Radio Eriwan? Basically, yes, but...
I'm not familiar with your car, but it's possible that you only have one temperature sensor for the engine, and your engine control unit (ECU) reads the engine temperature from that sensor. So, that's not how it works, but...
(That's likely the case if your temperature signal is coming from the MSG.)
If you modify the cockpit, remove the wiring for the instruments, and use an operational amplifier to correct the degraded boost pressure signal, then it might work (assuming you haven't already replaced the coil instruments with stepper motors).
I like the idea and I'll check it out myself when I have time; it might be something useful for my 'tips and tricks' collection.
After installing the oil temperature sensor (which is more important than the block temperature sensor in normal operation), that would be a great solution, and I could remove the modified air pressure fitting.
Translated on 26-08-2026, 16:19.
Avatar-Jan6K
Post06-11-2003, 14:23    Subject: Temperature Display as LDA? Misuse? Quote
I consider it almost hopeless. The display is implemented using stepper motors, and on top of that, there's this ramp function that makes a simple representation impossible.
Ultimately, this would result in a complete overhaul.
I'm currently working on a digital LDA (Laser Doppler Vibrometer) that functions similarly to what Rainer described some time ago, but uses an independent sensor. I'll write more about it when it's finished.
Jan.
1Z5 CFHF / AHB H4D
Translated on 26-08-2026, 16:21.
Gremlin
Post06-11-2003, 19:43    Subject: Temperature Display as LDA? Misuse? Quote
, but using an independent sensor. When it's finished, .
Why is that?
The original is linear, just tap it and it's good icon_smile.gif.
CU Gremlin.
Translated on 26-08-2026, 16:22.
Avatar-Jan6K
Post06-11-2003, 19:50    Subject: Temperature Display as LDA? Misuse? Quote
Hi Gremlin,
I want to be fault-tolerant. You won't detect defects in the original sensor that way, and there's also the risk that the additional circuit might introduce some interference into the system. Therefore, I want to build something completely independent, using an MPX4250AP as a basis. It's also linear icon_wink.gif}.
I wouldn't be surprised if it's also included in the original parts, as Motorola explicitly mentioned "automotive" in the datasheet.
Jan.
1Z5 CFHF / AHB H4D
Gremlin
Post06-11-2003, 20:12    Subject: Temperature Display as LDA? Misuse? Quote
No, the Bosch sensors are custom-made. At least, the micro-mechanical ones that are currently being used.
CU Gremlin.
Translated on 26-08-2026, 16:23.
No new posts Temperaturanzeige Diesel Engine Technology
No new posts Temperature Gauge A3 1.9 TDI Diesel Engine Technology
No new posts LED-Temperaturanzeige - wer kann helfen? Diesel Engine Technology
No new posts Temperaturanzeige MFA geht nicht Diesel Engine Technology
