What is PÖL? Definition & Explanation
F B
Post02-10-2005, 8:01    Subject: What is PÖL? Definition & Explanation Quote
Hi.
What exactly is 'Pöl'?
I'm now referring to Ald* because that's where the oil is currently the cheapest.
There is sunflower oil, and there is vegetable oil from rapeseed.
Is this completely crazy? Or does it have to be pure vegetable oil?
I'd like to try that, but not on a brand new common-rail diesel engine, but on an old Seat Terra, a real antique diesel.
Is rapeseed oil related to rapeseed?
Or how should I interpret this?
Hi Frank,
The fuel prices are driving me crazy.
PS: The maximum planned utilization is 50%.
Translated on 26-08-2026, 4:04.
Post02-10-2005, 9:06    Subject: What is PÖL? Definition & Explanation Quote
Okay, be honest, do you think this is just reinventing the wheel? What do you think about the relevant forums on this topic, of which there are plenty? Google is your friend. Or should we just do the research for you? I don't think anyone wants to do that!
Translated on 26-08-2026, 4:05.
F B
Post02-10-2005, 9:27    Subject: What is PÖL? Definition & Explanation Quote
@matthiasTDI96
My question is essentially about the term 'Rapsoel' and 'Ald* plant oil based on rapeseed' – are they the same thing?
You're right, I can find the rest of the information elsewhere.
Best regards, Frank.
Translated on 26-08-2026, 4:06.
donalexo
Post03-10-2005, 12:06    Subject: What is PÖL? Definition & Explanation Quote
@ F B:
"Pöl," short for Pflanzenöl, is a general term for all oils extracted from oil-bearing plants by pressing their fruits. This includes, of course, rapeseed oil, sunflower oil, olive oil, nettle oil, and many others.
Plant-based oils are typically offered as refined products in large supermarket chains. However, you can also purchase cold-pressed oils at oil mills.
It is important not to confuse this type of oil with RME (Rapeseed Methyl Ester), which is biodiesel. In this process, rapeseed oil is transesterified using a complex method to significantly reduce its viscosity (to the level of diesel).
If you search using the terms I mentioned earlier (Google, Pöl forums), you will find plenty of information.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 26-08-2026, 4:07.
F B
Post03-10-2005, 13:29    Subject: What is PÖL? Definition & Explanation Quote
@ F B:
Hi Alex,
'Ald* oil, which is based on rapeseed, has NOTHING to do with rapeseed methyl ester.'
THAT was what I wanted to know.
THANK YOU!
Translated on 26-08-2026, 4:08.
Hati
Post04-10-2005, 14:56    Subject: What is PÖL? Definition & Explanation Quote
Well, if we generously overlook the fact that RME is produced from rapeseed oil... icon_lol.gif
THEN you are right.
Translated on 26-08-2026, 4:09.
No new posts Where is Rainer, actually? Diesel Engine Technology
No new posts 10 Cent Tuning: How Does It Work? Diesel Engine Technology
No new posts Wie lange hält eigentlich ein TDI-Motor? Diesel Engine Technology
No new posts Is there actually a compatibility list...? Diesel Engine Technology
