'Background: My new turn signal lever with GRA (Gear Range Adaption) has finally arrived. But before I disassemble the car completely, I wanted to gather all the necessary materials. In my Ibiza, there isn't any wiring installed yet that reaches the relay panel, so first things first, I need to run some cables.'
Okay, how do I best connect the three strands to the MSG?
In the thread Error message after installing a GRA, it reads:
I had to crimp the 4 wires of the GRA onto the connector of the control unit using ferrules, because the pins absolutely did not fit into the socket.
And later on:
On the first start, everything was fine initially. After approximately 2 minutes of engine running time, the ABS light illuminated, followed by the red 'warning' light, and a triple beep sounded...
'...however, the ABS fuse (which is located directly next to the tapped fuse) has blown – a strange coincidence...'
I actually want to largely avoid such 'side effects' because I need the car
Now, how do I best solve this? The manual from Waltrop describes '3 connectors for connecting to the control unit,' but provides no further details.
Who can help? Thank you very much!
