How warm should a one-bedroom apartment be?
Post06-12-2003, 10:29    Subject: How warm should a one-bedroom apartment be? Quote
Hi.
Since I got my diagnostic interface, more and more questions have been coming up.
Last Sunday, I drove 150 km "under observation," from Kaiserslautern to Bitburg (which also included some hills).
Here's the result:
http://www.luxus-wg.de/~martin/auto_bilder/LOG-01-007-003-011.zip
The temperature of the water never exceeds 83 degrees Celsius. However, I've often read that "the vehicle should be at operating temperature, with water temperatures above 85 degrees."
I'll never be able to do it.
Does this indicate a faulty thermostat?
"There are no more errors in the memory. I deleted the '01117 Terminal DF implausible' error message, and it hasn't reappeared so far."
Thank you for the tips.
Translated on 12-07-2026, 19:36.
joergs
Post06-12-2003, 10:39    Subject: How warm should a one-bedroom apartment be? Quote
It depends on what type of thermostat is installed. In my opinion, there were/are some that go up to 83 degrees Celsius and others up to 87 degrees Celsius for coolant temperature. Also, the tolerance of the temperature sensor might play a role. I haven't looked at the log, but I wouldn't worry too much about it. A faulty thermostat would usually result in temperatures significantly below 80 degrees!
Translated on 12-07-2026, 19:38.
Sir Tortsch
Post06-12-2003, 11:34    Subject: How warm should a one-bedroom apartment be? Quote
but it's quite possible...
/viewtopic.php?t=3960&highlight=thermostat+z1
But in this case, the difference was greater...
joergs
Post06-12-2003, 11:40    Subject: How warm should a one-bedroom apartment be? Quote
but it is quite possible...
aber hier war halt die differenz größer ...
What did I write above? I myself have a damaged thermostat. And as I said, the temperature was clearly below 80 degrees!
Translated on 12-07-2026, 19:39.
Sir Tortsch
Post06-12-2003, 14:14    Subject: How warm should a one-bedroom apartment be? Quote
Okay, and I've also included a link to it below.
Translated on 12-07-2026, 19:40.
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How quickly does a water heater warm up? Diesel Engine Technology
No new posts A6 4F: Install Horn DWA System On-Board Diagnostics (OBD)
No new posts Fuel additives: Should you try them? Diesel Engine Technology
No new posts Passat 2.0 TDI - High pressure is below specification Dieselschrauber Bar
