LMM Diagrams: 1Z, AHU Engine Performance
Post16-12-2003, 1:04    Subject: LMM Diagrams: 1Z, AHU Engine Performance Quote
Hi.
Do you have any air mass values for your 1Z or AHU engines?
Then let me see it.
I am particularly interested in the performance above 3000 RPM under full load.
"So far, I've tested my 1Z and a colleague's AHU at 4200 RPM, and both started deviating from the target value of 850mg at exactly 3000 RPM. My 1Z even deviated quite significantly, to the point where the Russian border (presumably a limit or threshold) was exceeded."
http://people.freenet.de/golf-schrauber/dzr_lmm.gif
http://people.freenet.de/golf-schrauber/003.gif
http://people.freenet.de/golf-schrauber/008.gif
How about you?
Translated on 10-09-2026, 8:46.
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts AFN LMM getauscht 2x Messfahrt und Diagramme. beide hinü... On-Board Diagnostics (OBD)
