Temperature Display: Accurate Readings & More
harj
Post15-12-2006, 19:59    Subject: Temperature Display: Accurate Readings & More Quote
Hello everyone.
I think my coolant temperature gauge in the instrument cluster is broken.
How can I read this information using the 'climate control display'? Am I correct in assuming that parameter 51 refers to the engine temperature?
I could at least rule out the sensor in that case...
Or is there a dedicated sensor?
Best regards, Sepp.
A4, 2.5L, AFB; I'm seriously considering getting rid of the car...
javascript:emoticon('icon_evil.gif')
Evil or Very Mad.
Translated on 11-10-2026, 10:00.
bastion
Karma: +6 / -1   Thank you, like it!
Post15-12-2006, 20:14    Subject: Temperature Display: Accurate Readings & More Quote
Yes, the channel is correct. That is the actual cooling water temperature.
The coolant sensor is a dual sensor. It provides one reading for the instrument cluster (KI) with user-friendly values, and another reading for the engine control module (MSTG) with the correct temperature.
A4 Avant 08/01 AWX 05/08-
Translated on 11-10-2026, 10:01.
harj
Post16-12-2006, 20:51    Subject: Temperature Display: Accurate Readings & More Quote
Yes, the channel is correct. That is then the actual cooling water temperature.
The coolant sensor is a dual sensor. It provides one reading for the KI (instrument cluster) with user-friendly values, and another reading for the MSTG (module software test group) with the correct temperature.
So, I think I've already checked the one for the engine...
Where exactly is the sensor located?
Sepp.
Translated on 11-10-2026, 10:02.
bastion
Post16-12-2006, 22:37    Subject: Temperature Display: Accurate Readings & More Quote
It's located on the "belly" of the expansion tank. It's a 4-pin connector.
Translated on 11-10-2026, 10:03.
harj
Post17-12-2006, 21:16    Subject: Temperature Display: Accurate Readings & More Quote
On the 'belly' of the expansion tank. There is a 4-pin connector.
I found the sensor at the front, under the engine cover... I think it's a blue connector with 4 pins. It's strange that the climate control still showed 27°C even after I disconnected it.
I just checked, and parameter 51 refers to engine temperature. It seems there's probably another sensor involved.
I will be parameter 58 tomorrow. Hopefully, that will be the correct one...
I measured 2.2k ohms at one connection and 1.2k ohms at the other. Is the sensor broken?
Sepp.
Translated on 11-10-2026, 10:04.
Aron
Karma: +5 / -1   Thank you, like it!
Post17-12-2006, 23:42    Subject: Temperature Display: Accurate Readings & More Quote
harj wrote:
bastion wrote:
On the "belly" of the expansion tank. There is a 4-pin connector.
I found the sensor located at the front, under the engine cover... I think it's a blue connector with 4 pins. It's strange that the climate control still showed 27°C even after I disconnected it.
Sepp
I'm only familiar with this from Peugeot/Citroen and BMW, where there's a separate sensor on the radiator for the air conditioning system. Could this be the case here as well?
Translated on 11-10-2026, 10:05.
No new posts Temperature Gauge A3 1.9 TDI Diesel Engine Technology
No new posts Temperature Display as LDA? Misuse? Diesel Engine Technology
No new posts LED Temperature Display - Get Help Now! Diesel Engine Technology
No new posts Temperaturanzeige MFA geht nicht Diesel Engine Technology
