Trecker Treiber Guest
15-10-2003, 21:11 Subject: AAT Motor |
I have a question.
Are the fuel injectors of the AAT engine the same as those of the AEL  ?
olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
christians Profi-Schrauber
16-10-2003, 11:35 Subject: AAT Motor |
The AEL, unlike the AAT, has 5-hole nozzles.
Gruß Christian
16-10-2003, 17:25 Subject: AAT Motor |
Thank you for the information.
17-12-2003, 11:29 Subject: AAT Motor |
Late correction: The AEL nozzles with five holes have a more rounded bore design, which provides higher flow rates while maintaining the same atomization quality. They both have five holes.
Gruß Christian
Andi aus dem Ösiland Guest
17-12-2003, 12:04 Subject: Is a trade possible? |
Hi!
So, theoretically, you should be able to swap the AAT (Airflow Temperature) sensors with the AEL (Air-Fuel Ratio) sensors to potentially achieve a slight increase in performance, right?
Does anyone happen to have a photo of an AAT and an AEL piston?
Andi.
17-12-2003, 12:37 Subject: AAT Motor |
Of course, the Audi brochure from 1994/95 didn't go into much detail about the shape of the pistons. They are more likely to fit in the A6's AAT (air intake manifold) than in the Audi 100's.
Gruß Christian
