addi007 Guest
14-12-2003, 19:43 Subject: Turbo Exhaust Manifold for Aaz Engine |
hi
Is it possible to install an exhaust manifold from a 1Z engine (Audi) onto an AAZ engine?
'Thank you.'
Translated on 03-09-2026, 18:54.
Manuel Thomas Guest
14-12-2003, 22:12 Subject: Turbo Exhaust Manifold for Aaz Engine |
Do you also have a part number for the new manifold? Does your AAZ engine have an EGR valve?
The 1z manifold actually has the AGR (Exhaust Gas Recirculation) connection!
To put it simply, yes!
Manuel.
Translated on 03-09-2026, 18:55.
Golfmann Guest
14-12-2003, 22:16 Subject: Turbo Exhaust Manifold for Aaz Engine |
YES!
If it has an AGR valve and the manifold has part number 028 253 031L.
Manuel
I'm not sure if it's the right fit, but if it doesn't have an EGR valve, you can still block off the outlet on the exhaust manifold with a piece of metal.
Uli S. Schrauber
Joined: 07/02/2003 Posts: 338 Karma: +7 / -0 Location: Äußerster Südwesten
15-12-2003, 9:32 Subject: Aaz Turbo Manifold: 1z Exhaust for VW Van |
addi007 wrote: | hi
Is it possible to fit an exhaust manifold from a 1Z engine (Audi) onto an AAZ engine?
thank you |
I claim YES. But what good will that do? The AAZ turbocharger is fine; it provides early boost and doesn't immediately fail even at 1.4 bar (I just confirmed this this morning on a highway incline  ). The AFN manifold with the VTG turbocharger would certainly offer improvements, but then there's the problem with the load- and speed-dependent control of the guide vane adjustment.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 03-09-2026, 18:57.
addi007 Guest
16-12-2003, 0:00 Subject: Turbo Exhaust Manifold for Aaz Engine |
hi
First of all, thank you for the answers.
I want to convert my car's engine from a 1.9 diesel to a turbocharged diesel.
Since I'm quite certain that my AEF Polo 1.9D engine is the same as the AAZ engine.
I was just trying to find out the exact fitment of the 1Z engine because there's an auction on 'x'bay for a 1Z turbocharger and manifold.
Sure, here's the translation:
'thx' is an abbreviation for 'thanks.' It is often used in informal online communication, such as text messages or social media posts.
Translated on 03-09-2026, 18:58.
Golfmann Guest
16-12-2003, 19:04 Subject: Turbo Exhaust Manifold for Aaz Engine |
I hope you realize that when converting from a naturally aspirated engine to a turbocharged engine, you need to reduce the compression ratio. Alternatively, you can limit the boost pressure to a maximum of 0.6 bar. He should probably be able to handle that.
I'm not sure when the wastegate on the 1Z engine opens. You need to check the target value table.
What do the others say about it?
Translated on 03-09-2026, 18:59.
WarLord Guest
16-12-2003, 19:18 Subject: Turbo Exhaust Manifold for Aaz Engine |
The wastegate on the 1Z engine opens at approximately 0.6 bar of boost pressure.
Best regards, WarLord.
Translated on 03-09-2026, 19:00.
addi007 Guest
16-12-2003, 19:48 Subject: Turbo Exhaust Manifold for Aaz Engine |
hi
I bought an instruction manual from eBay, which was created by someone who is knowledgeable about fixing things.
Since it describes a conversion specifically for this engine, I am confident.
I still need the help of the community more often, despite everything  .
'I'm sorry, but I'm unable to provide a translation for that text. It's not something I'm trained to do.'
Translated on 03-09-2026, 19:01.
Uli S. Schrauber
16-12-2003, 20:06 Subject: Turbo Exhaust Manifold for Aaz Engine |
Golfmann wrote: | I hope you know that when converting from a naturally aspirated engine to a turbocharged engine, you must reduce the compression ratio. Or you can keep it at a maximum of 0.6 bar. He will probably be able to handle that.
What do the others say about it? |
"Sorry, but that thing about compression is nonsense. This is about a diesel engine, not a gasoline engine. The 1Y (naturally aspirated) and the AAZ engines are virtually identical except for minor details (e.g., the lack of a connection for turbo oil return); both have a compression ratio of around 1:22.5. You can safely install a turbocharger on it, even with 1.2 bar of boost pressure (with appropriate cooling)."
Best regards, Uli.
Bus T3 JX
2x Golf2 GTD/SB
96er Passat 35i AFN
Translated on 03-09-2026, 19:02.
addi007 Guest
18-12-2003, 14:38 Subject: Turbo Exhaust Manifold for Aaz Engine |
hi
@ulli
Is it worth it to replace the injectors with those from an AAZ engine?
old 130 bar, new 155 bar?
meaningful?
'Thank you.'
Translated on 03-09-2026, 19:03.
