AFN Injector Nozzles for AHU Engines
marco tdi
Post23-12-2003, 19:30    Subject: AFN Injector Nozzles for AHU Engines Quote
I'm here for the first time!
I bought fuel injectors for an AFN engine with 110 horsepower.
What benefits will I get from installing a 90 hp AHU engine?
Is there anything else that needs to be changed?
Best regards, Marco (Netherlands).
Translated on 23-08-2026, 18:34.
Post23-12-2003, 19:39    Subject: AFN Injector Nozzles for AHU Engines Quote
Hi.
Are you looking here?
marco tdi
Post23-12-2003, 23:00    Subject: AFN Injector Nozzles for AHU Engines Quote
'Thank you!'
And what about the turbo pressure?
Could I do something with the hose after the load pressure sensor (bypass)?
GR Marco (Netherlands)
Translated on 23-08-2026, 18:35.
Thomas
Post24-12-2003, 23:26    Subject: AFN Injector Nozzles for AHU Engines Quote
which, in turn, is stated here:
/viewtopic.php?t=3208
under: More boost pressure - only for newer vehicles.
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 23-08-2026, 18:36.
marco tdi
Post25-12-2003, 13:05    Subject: AFN Injector Nozzles for AHU Engines Quote
I installed the fuel injectors from AFN yesterday!
He ran very badly!
The amount was less than an SDI.
He doesn't smoke, and the pressure is slowly being released!
Dear Marco (from the Netherlands),
