Intercooler Installation: Guide & Tips
Mr.X
Post29-06-2002, 12:51    Subject: Intercooler Installation: Guide & Tips Quote
'Hi, has anyone here had any experience with upgrading the intercooler? I'm thinking of installing the intercooler from the 150 hp TDIPD engine into my own TDIPD (115 hp, AJM engine). The intercooler on the 150 hp version is mounted horizontally in the center of the bumper, which I think will get better airflow than the one in my wheel well. What should I be aware of when doing this? Do I need to make any changes to the electronics? I don't think so, because the boost pressure remains the same, it will just take a little longer to build up, and the amount of air shouldn't change, right?'
I would be grateful for any advice.
Stefan
Translated on 16-10-2026, 20:22.
Post29-06-2002, 14:54    Subject: Mechanical Problems: Common Issues & Solutions Quote
Hi.
The electronics probably do not need to be adjusted.
You have already mentioned the expected poorer response rate.
The rest should, in my opinion, just be a matter of craftsmanship.
Here's a request: If you really go through with this project, please do some before-and-after tests at 2000-4000 rpm (under as identical environmental conditions as possible), and post the results here so that we can have a reasonably well-documented understanding of what this actually achieves.
Translated on 16-10-2026, 20:24.
Animalking
Post01-07-2002, 11:05    Subject: Intercooler Installation: Guide & Tips Quote
Yes, exactly, including a detailed assembly instruction!! icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Translated on 16-10-2026, 20:25.
No new posts Turbocharger Installation: Guide & Tips Diesel Engine Technology
No new posts Replacing the TDI exhaust muffler Diesel Engine Technology
No new posts CAN Bus Control Unit: AHF-TDI Conversion? Diesel Engine Technology
No new posts ACV to AHY Engine Conversion Guide Diesel Engine Technology
