Hello, I've used the search function, but unfortunately, I haven't found anything. So, here's my question: Can I install the fuel injection pump from a 90 HP Passat TDI (with AHH engine code) into my 110 HP Passat TDI (with AFN engine code)? Are there any differences in the structure, or should I expect a performance decrease? Or does it simply work because it's the same [thing]?
