GRA in B4: Another Case?
edward
Post22-09-2003, 17:21    Subject: GRA in B4: Another Case? Quote
Hello everyone...
Unfortunately, I have to start a new thread again, this time about retrofitting a speed control system (terrible word...) into an Audi 80 Avant.
I've installed the steering column switch and now I'm looking for the connection to the electrical system. Since there wasn't a connector behind the steering wheel, I went to the dealership to ask about the wiring harness and the location of the connector. The answer I received wasn't very helpful: 'The wiring harness needs to be custom-made, and we can't tell you where the connectors are located...' Although it has been reported before in this community that a wiring harness needs to be created, I can't quite imagine that...
Okay, so here's the thing: I don't have the wiring diagram, and I have no idea where I would even run any custom-made cables. Maybe one of you could help me 'find' the right information, or give me the corresponding part numbers that I can show to the people at Audi...
Thank you very much.
Translated on 28-08-2026, 4:25.
mersente
Post14-02-2004, 22:04    Subject: GRA in B4: Another Case? Quote
Hello, it's possible that your engine control unit (ECU) is not configured for GRA (presumably referring to a specific feature or system). I'll check on Monday to see what's possible.
Translated on 28-08-2026, 4:26.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM: Another Instance? Diesel Engine Technology
No new posts Byte 18 again Electrical Systems, Vehicle Electronics, Multimedia
No new posts LMM and Diode Replacement: Troubleshooting Guide Diesel Engine Technology
No new posts 00575: Another Occurrence? Find Out Now! On-Board Diagnostics (OBD)
