Turbocharger pressure problem with ALH engine
Marzocchi
Post09-04-2004, 11:30    Subject: Turbocharger pressure problem with ALH engine Quote
Hello. I hope you can help me again.
I'm driving a Golf IV with the (still unmodified) 90hp ALH engine. Mileage: 99,000 km.
Recently, I installed a boost gauge (and I'm reasonably sure it was installed correctly), and it's showing the following readings:
"When I accelerate fully, then release the gas and immediately accelerate again, I experience overpressure spikes up to 1.5 bar (the maximum reading on the gauge). The needle usually stays at that point for about 0.5 seconds before dropping back to a very low pressure of around 0.65-0.7 bar. Then the pressure rises again to 0.95 bar. At 3000 RPM, I briefly reach 1 bar." Later, the pressure drops back to approximately 0.95 bar.
Actually, I'm supposed to set the pressure to 0.9 bar and have an overshoot of up to about 1.3 bar.
If I accelerate slowly, I also don't experience any pressure spikes above 1.3 bar.
The regulated boost pressure always remains between 0.95 and 1 bar.
I haven't experienced that situation in emergency mode before.
What's wrong with me, and what can I do about it?
Thank you for your help...
Bernd
Golf IV - ALH - Erstzulassung 9/99
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post09-04-2004, 12:11    Subject: Turbocharger pressure problem with ALH engine Quote
Your problem is not an isolated case; you are just one of a thousand.
as 1. VTG makes things easier.
2. Check all vacuum hoses for leaks.
3. The replacement turbocharger boost control valve.
but please search in the search functions, we've already discussed this a dozen times icon_wink.gif.
B.Eng (FH) u. KFZ Meister
Marzocchi
Post10-04-2004, 9:45    Subject: Could a faulty MAF sensor be the problem? Quote
It's often said that a faulty mass airflow sensor (MAF) can also affect the boost pressure.
Can this be ruled out as a cause for my problem? I'm still using the original one after almost 100,000 km. Shouldn't it have broken down by now? I don't want to just waste the money, though...
Sir Tortsch
Post10-04-2004, 20:12    Subject: Re: A faulty MAF sensor can't be the problem, right? Quote
It is often said that a faulty mass airflow sensor can also affect the boost pressure.
I haven't heard that before.
Can this be ruled out as a cause for my problem? I'm still using the original one after almost 100,000 km. Shouldn't it have broken down by now? I don't want to simply waste the money, either...
'In my ALH, it consistently delivered above-average performance until I sold it with 190,000 km on the odometer.'
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post11-04-2004, 17:59    Subject: Turbocharger pressure problem with ALH engine Quote
My A4 LMM (mass airflow sensor) now has 262,000 kilometers (approximately 163,000 miles) on it and is still producing readings around 900-1050.
icon_biggrin.gif Check your if it stays consistently above 850 when running at 4/5 full throttle, then...
Can you disable the "getrosst" feature and make your VTG (variable transmission gear) function normally?
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMR Loading Pressure Issue Diesel Engine Technology
No new posts Boost Problem Audi A6 2.0 TDI BLB On-Board Diagnostics (OBD)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
