AI coding?!
z-man
Post25-02-2004, 17:46    Subject: AI coding?! Quote
Hello!
'Can anyone help me? I want to replace my instrument cluster! It's a TDI MBK AHF, manufactured in 05/2000! I have a new instrument cluster! Since it includes the WFS, it needs to be programmed, just like the MSG and key. I also have the login code and VAG-COM.' Unfortunately, I have no idea what I need to consider or change.
I would be very grateful for some quick assistance!
Furthermore, how can I change the speedometer's coding? I want to change it from the current 240 km/h to 260 km/h. Possible?
Best regards.
'Micha'
brezelmann01
Post25-02-2004, 17:56    Subject: AI coding?! Quote
Use the search function! All the search terms you need, you have already used in your post... icon_rolleyes.gif
Good luck.
pretzel
joergs
Post25-02-2004, 17:57    Subject: AI coding?! Quote
Check this out.
Then, look for examples, and you should be able to find something to read for further information.
If you had used the search function, then... !!!!! http://www.vcds.shop/index_2.html
edit: brezelmann was faster!
z-man
Post25-02-2004, 18:28    Subject: AI coding?! Quote
Okay, my mistake!
But if I currently have a Generation II device, can I install an AI that's designed for Generation III? I have a device from 2002, and I'm not sure when Generation 3 started. If not, then I have a problem! icon_confused.gif
Best regards.
'Micha'
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motorsteuergerät codieren Diesel Engine Technology
No new posts Schlüssel und WFS codieren On-Board Diagnostics (OBD)
No new posts Coding the second battery? Electrical Systems, Vehicle Electronics, Multimedia
No new posts A3 8P SWRA codieren On-Board Diagnostics (OBD)
