Passat TDI: Cold Start Problems & Solutions
dicc
Post22-02-2004, 23:08    Subject: Passat TDI: Cold Start Problems & Solutions Quote
Hello everyone,
I'm having the following problem with my Passat 1.9 TDI, manufactured in 1994, engine code 1Z: The engine only starts after a long cranking period!
It started like this: the engine would start poorly, even when it was warm. I then replaced the diesel filter, but that didn't improve anything!
Since the timing belt was due for replacement anyway, I had it changed. However, there was no improvement, so I used VAG-COM to read the error codes.
'17978 - Engine Control Module Blocked by Immobilizer 35-10 - - - Intermittent'
That's probably the explanation for the startup problems that have occurred before.
'But now I'm having these problems every morning: the engine doesn't want to start (with the warm start problems, which I suspect are due to the immobilizer, the starter motor just spins and the engine doesn't even try to turn over). It only starts with a lot of gas and a long cranking period.'
Once the engine starts, it restarts immediately.
After further searching, I then replaced the four faulty glow plugs, but there was no improvement (apparently, the engine doesn't need them if everything is working correctly).
Then I reinstalled the old diesel filter, but that didn't help either!
What I also discovered using VAG-COM was that the timing values were slightly below the lower limit.
I'm desperate!!!!!!
DICC
Translated on 29-08-2026, 17:30.
Post23-02-2004, 7:18    Subject: Passat TDI: Cold Start Problems & Solutions Quote
dicc wrote:
What I also found out with VAG-COM was that the timing values were slightly below the lower limit!
Try using the search function. Enter "crankshaft bolt 1Z" and check the box that says "search for all words." Then you'll find everything important. Instead of "1Z," you can also try "AAZ" – the engine has the same problem as the early 1Z models.
/viewtopic.php?t=3313&highlight=crankshaft+screw+1z
http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
Translated on 29-08-2026, 17:32.
dicc
Post23-02-2004, 8:16    Subject: Passat TDI: Cold Start Problems & Solutions Quote
Hi, the screw and washer were also replaced when the timing belt was changed. I was shown the old washer, and everything looks okay.
DICC
Translated on 29-08-2026, 17:33.
Post23-02-2004, 10:58    Subject: Passat TDI: Cold Start Problems & Solutions Quote
dicc wrote:
Hi, the screw and the washer were also replaced when changing the timing belt. I was shown the old washer, and everything was okay.
DICC
Okay, then check your injection timing in the basic setting mode... if you're getting different values every day, that's perfectly normal.
Translated on 29-08-2026, 17:34.
dicc
Post23-02-2004, 12:03    Subject: Passat TDI: Cold Start Problems & Solutions Quote
'Injection start in the default setting mode' - where can I find this information exactly, and what should the normal value be? What does 'everything is clear' mean in this context, and what is a 'toothed wheel'?
DICC
Translated on 29-08-2026, 17:35.
Max d. Ä.
Post23-02-2004, 12:06    Subject: Passat TDI: Cold Start Problems & Solutions Quote
Have you ever checked the glow plug relay using the VAG-COM diagnostic tool? In my case, the problem was caused by a faulty relay. After replacing it, the 'organ-like' noise disappeared.
Bye.
Max.
Post23-02-2004, 12:07    Subject: Passat TDI: Cold Start Problems & Solutions Quote
Engine warm.
VAG COM
Engine.
Block 00.
Default setting.
Translate values 02 and 09 according to the usual conventions/graphics.
Translated on 29-08-2026, 17:36.
dicc
Post03-03-2004, 23:08    Subject: Passat TDI: Cold Start Problems & Solutions Quote
Hello everyone,
'The problem is fixed. I didn't want to mess around in the cold anymore, so I finally took the car to BOSCH. The cause was air in the fuel system! They replaced a section of damaged hose and installed a new (different) diesel filter (it seems this problem occurs more often with the old ones), and now it's running again!'
The new filter no longer has this 'check valve'; it's simply bypassed with a connector so that the diesel fuel flows directly back into the tank! (What is the actual function of this valve anyway?)
DICC
P.S. The filter has the Bosch part number 450906172 and costs €17.34, or the MANN WK842/3 is available from €8.95 online!
Translated on 29-08-2026, 17:37.
Post03-03-2004, 23:55    Subject: Passat TDI: Cold Start Problems & Solutions Quote
This large bump on the filter serves as a fuel pre-warmer.
It contains a bimetallic element that redirects cold diesel fuel back to the filter.
It only opens the bimetallic strip and allows the return flow back into the tank when a certain temperature is exceeded.
When the engine is cold, the diesel engine initially runs for a few short cycles before the ESP system warms it up more quickly -> this leads to better fuel atomization.
However, if there is a continuous short circuit, air may accumulate in the ESP (Electrostatic Precipitator), which is why the short circuit may clear after a certain amount of driving (i.e., heat).
While it's unfortunate that the part had to be removed, perhaps it was necessary to replace a potentially leaky connection.
That's why you now have much cheaper filters!
Translated on 29-08-2026, 17:39.
DJKasmic
Post04-03-2004, 16:47    Subject: Passat TDI: Cold Start Problems & Solutions Quote
@max: Where exactly can I find the actuator diagnosis for the glow plug relay?
Translated on 10-10-2026, 6:44.
Post04-03-2004, 16:52    Subject: Passat TDI: Cold Start Problems & Solutions Quote
mit VAG-COM
ans MotorSTG verbinden
- 03 Outputtests
Dann macht er verschieden Sachen durch.
Nicht erschrecken N109 ist der Absteller, da geht der Motor aus !!!
Danach kommt irgendwann das Vorgluehrelais
Translated on 29-08-2026, 17:40.
Gremlin
Post04-03-2004, 20:13    Subject: Passat TDI: Cold Start Problems & Solutions Quote
So dreht der Diesel bei kaltem Motor erst ein paar Kurzschluss-Runden und wird in der ESP schneller warm -> bessere Zerstaeubung.
eigentlich ist das ja zur filterheizung gedacht, um ausflockung im winter zu vermeiden icon_wink.gif
@dicc
danke für die rückmeldung !
CU Gremlin
Max d. Ä.
Post04-03-2004, 20:46    Subject: Passat TDI: Cold Start Problems & Solutions Quote
dieselmartin schreibt:
'mit VAG-COM
- 03 Outputtests
Danach kommt irgendwann das Vorgluehrelais' .
So ist´s. Am besten den Motor erst gar nicht starten, nur Zündung ein. Im Menue wird dir dann u.a. der Test des Vorglührelais und danach der Test des Relais für die kleine und die große Kühlwasserheizung angezeigt. Bei den letzen beiden kannts du dann auch das 'kochen' des Kühlwassers im Motorraum vernehmen.
Tschüss
Max
No new posts Golf 1J Radio Issues: Troubleshooting Guide (KW 43/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts AVF Cold Start: Troubleshooting & Solutions Diesel Engine Technology
No new posts TDI Cold Start 1Z 90PS Diesel Engine Technology
No new posts V6 TDI: Smoking on Cold Start (2002) Diesel Engine Technology
No new posts Skoda Superb: 2.5 TDI Cold Start Problems On-Board Diagnostics (OBD)
