Clutch Replacement: Nissan Almera N16
AlmeraN16
Post13-03-2004, 17:23    Subject: Clutch Replacement: Nissan Almera N16 Quote
Hello everyone!
I drive a Nissan Almera N16 2.2 TDI.
Until the day before yesterday, I had no problems with my car. Yesterday, I suddenly noticed that the clutch only engages fully at the very last moment. The actual position of the engagement point seems to be the same, but the range between the engagement point and full clutch engagement has become very large.
I then performed the so-called 'clutch tests.'
- Release the clutch in 2nd gear while the handbrake is engaged --> The vehicle will stall.
- Full throttle in 5th gear --> no clutch slippage.
The car has only 65,000 km on the odometer and is mostly driven on the highway. Could it be that the clutch is nearing the end of its lifespan? If so, why would it suddenly fail? Is there possibly a problem with the clutch hydraulics?
Thank you very much for your help!!!
Best regards.
Marc.
Translated on 09-09-2026, 13:34.
mersente
Post13-03-2004, 18:24    Subject: Clutch Replacement: Nissan Almera N16 Quote
Hello, it's possible that oil from the engine or transmission is leaking onto the clutch.
If your Nissan has a hydraulic clutch actuation system, fluid can also leak from there into the clutch.
The connection will naturally be established later, and in extreme cases, it may not be established at all.
Translated on 09-09-2026, 13:36.
AlmeraN16
Post13-03-2004, 18:43    Subject: Clutch Replacement: Nissan Almera N16 Quote
@mersente
Thank you for your reply!
I could have easily imagined oil being present in the clutch, but the clutch's hydraulic system seems to be sealed. Everything around the clutch is also dry.
The oil seal on the release lever is in good condition.
Sure, here's the translation:
'Any other ideas?'
Translated on 09-09-2026, 13:37.
No new posts Worn clutch disc pressure plate bearing, Golf/Bora 85KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Nissan Almera 2.0D: Jerking, Stuttering, or Hesitation? Diesel Engine Technology
No new posts Nissan Almera Tino: Too much of a good thing? Diesel Engine Technology
No new posts Worn Clutch? Get Clutch Replacement Now! Diesel Engine Technology
No new posts Clutch Worn Out After 14,000 km? Diesel Engine Technology
