How close can Nm and Russian borders be to each other?
Post07-03-2004, 22:48    Subject: How close can Nm and Russian borders be to each other? Quote
Hi.
I kicked my 1Z today to see what its top speed is.
I noticed that the torque and Russ limits are often very close together (often Russ is only 0.2 mg above the torque limit).
Sometimes, even Russ makes mistakes.
Is this a reason for a new language model?
How will VW react if I give them a mass airflow sensor (MAF) that I've modified with Ulf's 22kOhm trick for replacement? Will they accept it back?
The log file is located here: http://www.luxus-wg.de/~martin/auto_bilder/LOG-01-003-008-011.zip
It's interesting that the Russian border was closed at 205 and 4400 RPM (measurement point 740 ff).
No new posts Doku Polo MJ 2001, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J1214, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P-Box: Differences Explained Diesel Engine Technology
No new posts Diesel Filter: Causes of Engine Surging? Diesel Engine Technology
No new posts What are the differences between VP34 and VP37? Diesel Engine Technology
No new posts AFB High Fuel Consumption: Common Causes Diesel Engine Technology
