MFA Consumption Change with VAG-COM
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post29-01-2004, 21:03    Subject: MFA Consumption Change with VAG-COM Quote
Hello.
Since I soldered my RDI chip onto my control unit six months ago,
My fuel gauge always shows about 1 liter less than the actual amount.
She typically uses about 5.5 liters. Then, to fill it completely, you need to calculate and add more, roughly 6.5 liters. icon_idea.gif
Can I make any adjustments using VCDS?
Or could it possibly be due to an incorrect map from the chip? But if that's the case, then I'm powerless. icon_twisted.gif
Oh, almost forgot, there's an Audi A4 B5 with an AFN engine! icon_arrow.gif icon_redface.gif
Translated on 16-09-2026, 8:33.
Post30-01-2004, 16:20    Subject: MFA Consumption Change with VAG-COM Quote
Sounds like a "stupid" chip.
He would probably just have to do something simple, like tamper with a device to falsify measurements.
This disrupts the feedback loop for fuel injection, resulting in increased power and inaccurate MFA (presumably Multifunction Display) readings.
Here's the same question...
/viewtopic.php?t=4959&highlight=box+mfa
Translated on 16-09-2026, 8:34.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post30-01-2004, 20:09    Subject: MFA Consumption Change with VAG-COM Quote
Well, I actually hope that's not the case, and that the chip is actually good.
However, the link doesn't really help me either.
And on a chip, there are completely new identification fields. icon_question.gif
Translated on 16-09-2026, 8:35.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post02-02-2004, 23:47    Subject: MFA Consumption Change with VAG-COM Quote
I found something in the Elsa program about how to adjust the MFA (presumably a setting related to energy consumption) so that it aligns with the desired usage. According to what I read in Elsa, it can be increased in steps of 3%. I'll post the instructions once I have a printed copy!
Can it really be true that at rdi-motorsport.de, they don't accurately adjust the calibration data in the chip, but only manipulate values like temperature, boost pressure, and injection timing? icon_mad.gif If I could find out about this, there would be a huge uproar. icon_twisted.gif Because then...
I would feel like I'm being completely ripped off. They can tell you anything, they can swear you up and down! icon_rolleyes.gif
Translated on 16-09-2026, 8:36.
Post03-02-2004, 6:58    Subject: MFA Consumption Change with VAG-COM Quote
Steffarn wrote:
I found something in the Elsa program about how to adjust the MFA so that the consumption matches again. It says you can increase it in 3% increments, as I read in Elsa. I'll post the instructions when I have a printed copy!
The search function is your friend. The instructions in our error database are for the G4 model.
z.B.: https://community.dieselschrauber.org/en/viewtopic.php?t=1037 und weitere ...
Translated on 16-09-2026, 8:38.
Mc_Givertechnik
2010 Volkswagen T5
Post03-02-2004, 7:39    Subject: MFA Consumption Change with VAG-COM Quote
Hello!
Gleich zu diesem Thema eine Frage. Wie kann ich das heraus finden, ob nun mein Chip nur Werte verfälscht oder wirklich andere Kennfelder verwendet??? Es wird ja wohl schwer sein, anhand der Sollwerte zu vergleichen, da die neuen Kennfelder, so fern vorhanden, ja von anderen Sollwerten ausgehen. Hmm, yes, but how?
Regards, Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 16-09-2026, 8:39.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post03-02-2004, 18:43    Subject: MFA Consumption Change with VAG-COM Quote
Thank you for the link; I had been looking for it but couldn't find it.
The issue with the chips really scares me. I believe my next chip will also be from a reputable tuner. icon_wink.gif
I thought that those cheap chips were just copies (burned), and therefore shouldn't actually differ from the genuine ones! icon_question.gif
Translated on 16-09-2026, 8:40.
Post03-02-2004, 20:59    Subject: MFA Consumption Change with VAG-COM Quote
Mc_Givertechnik wrote:
How can I determine whether my chip is simply distorting values or actually using different characteristic curves??? It will probably be difficult to compare based on the target values, since the new characteristic curves, if they exist, would be based on different target values. Hmm, yes, how can I do that?
Hi Peter,
Based on the sensor manipulation techniques similar to those used in Powerbox devices, the following should be checked:
If the car performs significantly better,
-> without consuming more, according to BC .
-> or, without injecting more fuel according to VAGCOM.
It could be a complete engine control unit (ECU), a simple tuning module, or even just a chip that manipulates sensor data (e.g., air mass flow, diesel temperature, etc.) to achieve a higher fuel injection volume.
If the amount of fuel being injected or the instantaneous fuel consumption increases logically with the increased power output, then it's likely that a more "honest" chip is installed.
Translated on 16-09-2026, 8:41.
Post05-03-2004, 8:33    Subject: MFA Consumption Change with VAG-COM Quote
Brösel wrote:
I would like to raise my question again:
What happened to CHANNEL 03 in the combination (regarding MFA display/consumption adjustment)?
Cannot be adjusted/modified!!!
Who can help or check this out themselves?
"That's completely correct; this function was no longer included in the combination instrument panels from mid-2001 onwards. It's the same for me."
Translated on 16-09-2026, 8:43.
