Hello!
The odometer matches the service record, and the previous owner says the same.
It seems that this is okay.
It doesn't necessarily have to mean anything!
Here's the translation:
'Firstly, service books are sometimes 'tampered with.' This unfortunately happens occasionally when a car dealership wants to resell a trade-in vehicle (with or without a mileage that has been altered by the previous owner) without proper service book maintenance. Further investigation may be necessary if the service book does not include a receipt number for each service. If a receipt number is present, it is highly likely that the service was actually performed. To verify this, a copy of the receipt can easily be requested from the dealership using the receipt number.'
'The car dealership records what they read from the odometer in the service booklet. Using relatively inexpensive software available on eBay, almost any digital odometer can be easily adjusted multiple times (assuming some basic technical knowledge). So, if the previous owner consistently exceeded the mileage intervals between inspections by 10,000 km and then reduced the odometer reading by 10,000 km before bringing the car in for inspection, they would still have a complete and seemingly accurate service history.'
Asking the previous owner is a good idea, but if someone tampered with the odometer, it was probably him.
But I wouldn't assume that right away. I favor the following explanation:
I'm just going to believe my friendly colleague that they were too inexperienced to find the error the first time.
I also believe that, perhaps they exaggerated something in the error description. I can imagine that, for example, only the fuse for the glow plug system was blown. And that the dealer admits to not finding such a simple error...
Well, they might get creative and invent completely nonsensical errors. But those are just my speculations...
But the thing about the spray painting is now worrying me.
I obviously
wasn't shown the candles.
A competent Volkswagen technician should notice something like that during the disassembly process and, if necessary, point it out to you!
Private.
