Wastegate and EGR Valve Test with Injector Cleaner
Post11-03-2004, 16:06    Subject: Wastegate and EGR Valve Test with Injector Cleaner Quote
Hi.
What size syringe would be appropriate for testing the EGR valve and the wastegate (once with suction, once with pressure)?
Hopefully, the pharmacist won't ask about the purpose icon_lol.gif.
Translated on 23-08-2026, 14:10.
Post11-03-2004, 18:14    Subject: Wastegate & EGR Test: Check with Injector Nozzle Quote
dieselmartin wrote:
What size syringe should be used to test the EGR valve and the wastegate? (Once pulling, once pushing)?
Hi Martin,
I already have a 60 ml apparatus.
It should be enough vacuum to activate the wastegate, but even with this piece (with only one vacuum connection), I can't get the EGR valve to open more than halfway.
To fully open it, I have to squeeze/pinch the tube and reattach the syringe. . . icon_sad.gif
My pharmacist actually grinned when I told him what I needed the thing for.
I don't know if he believed me or not...
Translated on 23-08-2026, 14:11.
haehnlein
Post11-03-2004, 19:19    Subject: Wastegate and EGR Valve Test with Injector Cleaner Quote
Hi Martin,
I also have a 60 [model] and was able to disassemble the EGR valve without any problems (even with my mouth -> so it's still easy to move). Of course, this also depends on the length of the hose in between. The shorter, the better. Please let me know if you can move your wastegate as easily as Ulf did (um... moment, didn't you used to have an AFN icon_confused.gif)?
____________
Kein Auto mehr!
Translated on 23-08-2026, 14:13.
Post11-03-2004, 21:19    Subject: Wastegate and EGR Valve Test with Injector Cleaner Quote
haehnlein wrote:
Please let me know if you can move your wastegate as easily as Ulf does (um... wait, didn't you used to have an AFN icon_confused.gif?)
Okay, but just to be on the safe side, I estimated that a full 60 ml syringe should be enough icon_rolleyes.gif.
Translated on 23-08-2026, 14:14.
josie
Post14-03-2004, 23:15    Subject: Wastegate and EGR Valve Test with Injector Cleaner Quote
At Aldi, sometimes there is a syringe available for sale that has a volume greater than 500 cm³. It can be used for both suction and pressure. icon_lol.gificon_idea.gif
Translated on 23-08-2026, 14:15.
Rudi
Post15-03-2004, 12:52    Subject: Wastegate and EGR Valve Test with Injector Cleaner Quote
Ask your trusted veterinarian.
The 200ml versions (which are normal for cattle, horses, etc.) work great icon_cool.gif.
Best regards, Rudi.
Post15-03-2004, 12:58    Subject: Wastegate and EGR Valve Test with Injector Cleaner Quote
Okay.
Thank you for your tips.
With 3 pharmacists and a agricultural engineer in the family/circle of friends, that should work out icon_smile.gif.
Translated on 23-08-2026, 14:16.
No new posts Wastegate, boost control valve Diesel Engine Technology
No new posts Wastegate Question: Troubleshooting & Explained Diesel Engine Technology
No new posts Frage zum Wastegate Diesel Engine Technology
No new posts Berechnung Wastegate Diesel Engine Technology
