Such a Log vim AFN (Gfx inside)
Post15-03-2004, 13:46    Subject: Such a Log vim AFN (Gfx inside) Quote
I recorded the boost pressure over speed during a normal drive:
http://people.freenet.de/golf-schrauber/LDD-Umin.gif
Can an AFN driver provide this data for logging (e.g., 011 or 010)? (Ideally over a longer period, such as my graph showing 1.5 hours on the highway)
Post15-03-2004, 13:59    Subject: Such a Log vim AFN (Gfx inside) Quote
Oops, there I go again with blueberries:
Here's what I was planning:
http://people.freenet.de/golf-schrauber/LDD_1Z_AFN.gif
The AFN doesn't actually arrive significantly earlier with the higher boost pressure?
BlauBaer
Post15-03-2004, 20:23    Subject: Such a Log vim AFN (Gfx inside) Quote
hi,
frage: what do you mean by 'earlier'? I thought the 1Z and the AFN both had a maximum pressure of 1900 U/min. So, what's different about that??
Greetings
Avatar-Jan6K
Post15-03-2004, 20:43    Subject: Such a Log vim AFN (Gfx inside) Quote
At 1900, it achieves the maximum torque, while the maximum boost pressure is significantly lower. You can clearly see this when you have a high load and low RPMs, because otherwise it would normally spin out of the range too quickly.
I didn't really pay close attention, but yesterday when accelerating from 60 mph in 5th gear (with 4 people, luggage, and going uphill) after passing an Autobahn construction site, I had 1 bar of boost at 1500 rpm.
Log is currently not possible, I need to find time to modify the power supply so that it grounds the notebook power supply.
Jan
1Z5 CFHF / AHB H4D
BlauBaer
Post15-03-2004, 21:06    Subject: Such a Log vim AFN (Gfx inside) Quote
So, bei 1500 U/min sollte der 'target LD' (oder 'target Luftdruck') nicht einmal 1 bar betragen...der 'target LD' von 1 bar sollte bei ca. 1900 U/min liegen...und das funktioniert.
Greetings
No new posts 003 and 008 Log from ASV inside On-Board Diagnostics (OBD)
