Twister LF by KW-Systems
Tobias
Post14-06-2002, 12:37    Subject: Twister LF by KW-Systems Quote
Hello fellow diesel enthusiasts,
http://www.kw-systems.de/twister.htm
Thank you for your posts.
Best regards from Lake Constance.
Georg_G
2012 Volkswagen Golf
Post14-06-2002, 14:32    Subject: Twister LF by KW-Systems Quote
Hello.
Actually, I prefer the standard air filter with its very large surface area, which allows air to flow straight through. I'm not a big fan of strong currents, but the turbulence within this "hood" might be quite significant.
Conclusion: Yes for better sound, no for better performance. You can achieve a similar result to what Ulf described by simply attaching the stock air filter box to the rear wall. "Kilingt" also translates to "sounds good" in English.
Best regards, Georg.
No new posts KW-Systems P-Box with ALH Engine and Age-Related Issues Diesel Engine Technology
No new posts KW Systems Powerbox: No More Charging Issues:x Diesel Engine Technology
