Avenga Guest
03-03-2004, 0:48 Subject: Poweroil: High-Performance Motor Oil |
Hi, I wanted to know what you think about this oil.
http://www.poweroil.de/poweroil0w40.htm
costs €25 for 5 liters.
so cheap, does it actually work?  You can create their website in 5 minutes.
Translated on 10-08-2026, 21:54.
03-03-2004, 10:05 Subject: Poweroil: High-Performance Motor Oil |
I've heard of it.
But I preferred to ease my conscience by using "brand-name" oil.
If they weren't lying about the VW standards, then it should be sufficient for VP-TDIs.
For PD, this means absolutely nothing!
Translated on 10-08-2026, 21:55.
Profile PM Garage |
Thomas K. Guest
03-03-2004, 11:43 Subject: Poweroil: High-Performance Motor Oil |
Poweroil also offers an oil specifically for diesel engines, available at Marktkauf under their 'Gut&Billig' brand, with the specification 5W-40 and meeting the VW standard 505.01.
5 liters for €29.99.
The bottle says 'approved by VW.' I don't believe that the Marktkauf corporation would sell a product under its name that advertises being 'approved by VW' but is not officially approved.
I suspect that behind the 'Poweroil' brand there are other brands and customers, meaning it's likely a private label product from a well-known manufacturer.
I've used it myself in my AJM and I don't notice any difference compared to branded oils.
Translated on 10-08-2026, 21:57.
joergs Guest
03-03-2004, 12:38 Subject: Poweroil: High-Performance Motor Oil |
I hope you also have analyses of the 'gut&billig' supermarket products? In fully synthetic oils, an extremely high content of mineral components was detected. This was found in a 10w40 fully synthetic oil with the specification 505.00, and that makes me wonder! Why should it be different with the PD oils?
Translated on 10-08-2026, 21:58.
Thomas K. Guest
03-03-2004, 12:55 Subject: Poweroil: High-Performance Motor Oil |
Where can I read such test reports or analyses? Do you have anything for me  ?
10W-40 is definitely not a full synthetic oil; it's always a semi-synthetic or hydrocracked oil, which means it's a refined mineral oil (by the way, the 5W-40 PD oil with specification 505.01 is also only semi-synthetic or hydrocracked).
Translated on 10-08-2026, 21:59.
joergs Guest
03-03-2004, 13:54 Subject: Poweroil: High-Performance Motor Oil |
That's right! But it says 'full synthetic' on the label.
Where can I find the test report? I don't remember! But I'm looking for it.
Translated on 10-08-2026, 22:00.
03-03-2004, 13:58 Subject: Poweroil: High-Performance Motor Oil |
@ Thomas K.
Exactly, because I was already having trouble finding a fully synthetic 5W-40 50500 oil.
Almost all fully synthetic oils are now designated as "0W" oils.
Translated on 10-08-2026, 22:01.
Profile PM Garage |
Thomas K. Guest
03-03-2004, 14:06 Subject: Poweroil: High-Performance Motor Oil |
Yes, that's true; there are fewer and fewer genuine full synthetic oils available. Or perhaps they have all been misleading us with their advertising, or maybe a clear standard has been introduced for this  .
'By the way:'
You can find a good 5W-40 hydrocracked oil at the Praktiker hardware store for €10.95 for a 5-liter container. The brand is High Star. The packaging even lists specific approvals according to VW 505.00, 502.00, Porsche, BMW Longlife98, MB 229, etc.
You can find this information in the fine print. The manufacturer is Addinol Leuna. They even supply Volkswagen with this product for initial filling at the factory.
I've been using this for 3 years in my wife's Peugeot 206 --> it's excellent.
Translated on 10-08-2026, 22:02.
Thomas K. Guest
03-03-2004, 14:11 Subject: Poweroil: High-Performance Motor Oil |
Hello again,
I was just browsing their website a little bit. There isn't much to find.
Basically, they don't do anything different from companies like Castrol; they buy oil from refineries and have it filled directly into their bottles. They don't manufacture anything themselves. It's possible that, for example, their 5W-40 oil is identical to a Castrol oil.
Translated on 10-08-2026, 22:04.
FBonNET Guest
04-03-2004, 11:22 Subject: Poweroil: High-Performance Motor Oil |
I use fully synthetic 5W40 engine oil from the Globus MultiLub house brand, and I've been using it for almost 100,000 kilometers. So far, everything has been great. Visually, everything looks verschandeln under the valve cover.
Okay, the 5-liter container is on sale for €20, normally it costs €30.
Translated on 10-08-2026, 22:05.
joergs Guest
04-03-2004, 11:52 Subject: Poweroil: High-Performance Motor Oil |
'That's exactly what I use! It costs me €17.95 when it's on sale and €19.95 normally. I bought it from ZACK, not Globus. My old car, a 1Z, has been running with this product for about 150,000 km without any issues or problems!'
Translated on 10-08-2026, 22:06.
To Guest
04-03-2004, 21:14 Subject: Poweroil: High-Performance Motor Oil |
@ Thomas K.
Okay, because I was already having trouble finding a fully synthetic 5W-40 50500 oil.
Almost all fully synthetic oils are now designated as '0W' oils.
For example, Valvoline SynPro 5W-40 or Pentosin Pentosynth 5W-40.
Tobias.
P.S.: I hope that these oils do not contain any mineral components.
Translated on 10-08-2026, 22:07.
To Guest
04-03-2004, 21:40 Subject: Poweroil: High-Performance Motor Oil |
I hope you also have analyses of the Gut & Billig supermarket products? In fully synthetic oils, a very high content of mineral components was detected. http://www.autobild.de/suche/artikel.php?artikel_id=1574&A_SESS=ba649f491d789a3c33b95729188c4de7
Hello Jörgs,
Did you mean this analysis from Auto Bild?
Tobias.
Translated on 10-08-2026, 22:08.
joergs Guest
05-03-2004, 8:22 Subject: Poweroil: High-Performance Motor Oil |
hello tobias,
No, that wasn't it, because this is a partially synthetic product, not a fully synthetic one. I'm still searching and hope to find it!
Translated on 10-08-2026, 22:09.
maxxx Guest
21-03-2004, 11:55 Subject: Poweroil: High-Performance Motor Oil |
hello
Yesterday, I couldn't find any oil for my AJM-PD engine, manufactured in 2001 (not longlife), that meets the 505.01 standard at Praktiker.
I just bought the most expensive Castrol oil (specifications 50500 and 50200), specifically the Race 0-W40 and Formula RS, which is fully synthetic. It cost €51, but with a 20% discount because everything is currently on sale.
Is that okay?
Translated on 10-08-2026, 22:10.
joergs Guest
21-03-2004, 12:39 Subject: Poweroil: High-Performance Motor Oil |
If it doesn't meet the norm 50501 standard (i.e., without the longlife specification), I wouldn't use it, no matter how cheap it is. The 50500 oil can't withstand the usual pressure differences between the engine and the particulate filter element in a diesel particulate filter (DPF) system. It's difficult to find oils specifically for DPF systems at hardware stores. And even when you do find them, they are often partially synthetic. Take a look at www.reifendirekt.de; they have DPF oils at relatively good prices.
Translated on 10-08-2026, 22:11.
