Set Grant Start Date
TDI Butze
Post24-03-2004, 19:07    Subject: Set Grant Start Date Quote
Hello!
Here's what my diagram looks like after a timing belt replacement...
[Dead link]
Okay, I have a question... in which direction do I need to turn the pump to get closer to the ideal line?
And out of curiosity, where is 'early' and where is 'late'? Does 'early' mean the upper tolerance limit?
'Thank you!'
Matthias
Translated on 08-10-2026, 3:43.
Post24-03-2004, 19:35    Subject: Set Grant Start Date Quote
Take a look at where the values in MWB 0, value 2, move when you accelerate; that indicates it's happening too early.
Translated on 08-10-2026, 3:44.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts AFB V6 TDI - When to stop fueling? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Start subsidy, model 1Z, year of manufacture 1996 Diesel Engine Technology
No new posts ARL: Set Start Date for Grants. On-Board Diagnostics (OBD)
No new posts 1.6 TDI: Adjust Power & Injection Timing Diesel Engine Technology
