TDI AFN Burn Pressure: Explained & Troubleshooting
calumato
2004 BMW X5
Post24-03-2004, 11:54    Subject: TDI AFN Burn Pressure: Explained & Troubleshooting Quote
I'm having the following problem:
To select the correct sensor for a cylinder pressure measurement, I need some information about the pressure ranges I can expect.
"Does anyone have information about the 1.9L TDI engine, specifically the AFN type, or perhaps a complete wiring diagram?"
It would be great if you could help me.
Matthias.
Translated on 02-09-2026, 15:48.
Gremlin
Post24-03-2004, 13:56    Subject: TDI AFN Burn Pressure: Explained & Troubleshooting Quote
I am unable to access external websites or specific files online, including the URL you provided. Therefore, I cannot translate the text from the German link.
CU Gremlin.
Translated on 02-09-2026, 15:49.
calumato
2004 BMW X5
Post24-03-2004, 14:35    Subject: TDI AFN Burn Pressure: Explained & Troubleshooting Quote
Hello Gremlin,
You're right, I probably didn't look closely enough.
To put it more precisely:
I have a pressure sensor with a maximum pressure rating of 150 bar.
I am also aware that the previous engine, with its 66 kW output, had a maximum combustion pressure of 140 bar.
What is the pressure for the AFN type?
It's a matter of cost. These things aren't exactly cheap.
Matthias.
Translated on 02-09-2026, 15:50.
Gremlin
Post24-03-2004, 15:52    Subject: TDI AFN Burn Pressure: Explained & Troubleshooting Quote
Okay, I'm thinking about the worst-case scenario and would opt for one with a 200 bar rating.
There are always some stupid coincidences...
See you, Grem,lin.
Translated on 02-09-2026, 15:51.
