Alternator Failure After Engine Wash A3 ALH?
Waldi
Post04-04-2004, 15:14    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Hello!
I've been having the following problem since yesterday:
After the engine cleaning, the charging indicator light remains on, and the alternator is not charging the battery.
Did the washing process damage the voltage regulator? All the cable connections to the alternator are dry and in good condition. Even warming up the alternator to dry it out and blow away any moisture didn't help.
How should I proceed (troubleshooting, removing the alternator cover, replacing the voltage regulator, costs)?
Best regards & thank you,
Waldi.
Vehicle: A3 TDI, Engine Code: ALH, Year: 1998.
Translated on 01-10-2026, 11:45.
Post04-04-2004, 18:51    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Waldi wrote:
How should I proceed from here (troubleshooting, removing the cover of the alternator, replacing the voltage regulator, costs)?
I don't know how to disassemble your bra.
But you can check the regulator yourself (with some hardware) as follows:
Attach a test lamp to the carbon brushes.
Apply a variable DC voltage between the terminals of the excitation diodes and ground.
The test lamp should light up at a voltage of approximately 14 to 14.5 volts, and it should turn off at a higher voltage, with the cutoff threshold being a few millivolts higher than the turn-on threshold.
If the regulator is doing that, it's most likely okay, and the problem lies elsewhere.
Does voltage reach the terminal for the charging indicator light on the port side when the engine is not running?
Translated on 01-10-2026, 11:47.
Post04-04-2004, 20:09    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
I used to have that too...
After a night of drying, everything was back to normal.
Translated on 01-10-2026, 11:49.
Waldi
Post05-04-2004, 15:05    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Hello!
I've already replaced the voltage regulator, and everything is working again. It wasn't a pleasant experience to get to, but it helped.
'First, my dealer told me that the regulator wasn't sold separately, but only as a complete alternator replacement, for something like 300 euros plus tax. That's shocking! But another Audi dealer actually had the regulator in stock. It cost 52 euros.'
Waldi.
Gremlin
Post05-04-2004, 18:47    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
if it's a Bosch-Lima, even a visit to the Klingons might help icon_wink.gif.
A quick look at the catalog 'Parts for Starters and Generators' can be helpful...
CU Gremlin.
Translated on 01-10-2026, 11:50.
Julian
Post05-04-2004, 19:26    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Hm, so, the ALH Golf 4 always has the option of regulator replacement for the 120-type wipers from Valeo and Bosch. icon_wink.gif
Translated on 01-10-2026, 11:51.
Martin R
Post05-04-2004, 19:45    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Hmm, so the ALH Golf 4 always has the option of changing the regulator when using 120-type wipers from Valeo and Bosch. icon_wink.gif
The regulator can actually be replaced in almost any alternator.
(I haven't seen a single one in 12 years where that wasn't the case).
Of course, it requires more effort for some people (removing the engine, disassembling it) than for others.
Julian
Post05-04-2004, 19:58    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Hmm, yes, but I heard that VW used a similar Lima manufacturer in the Golf 4, where it supposedly shouldn't work. However, I don't know the manufacturer's name or whether that information is correct.
Translated on 01-10-2026, 11:52.
Arthur Dent
Post06-04-2004, 7:54    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
I have a 120A Hitachi alternator in my G4 ALH. According to the dealer, it is definitely not possible to replace the regulator (which is unfortunately defective in mine).
I'd be happy to be proven wrong, as it would save me a lot of money!
Translated on 01-10-2026, 11:53.
Martin R
Post06-04-2004, 19:44    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
Can you give me the Hitachi number for the Lima?
Arthur Dent
Post08-04-2004, 12:18    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
@ MartinR
The label on the battery shows the following information: Hitachi 120A, 14V.
VW Part No.: 028903029G
LR 1120-701
I'm not sure if the second one is a Hitachi model.
Thank you, Thomas.
Translated on 01-10-2026, 11:54.
Martin R
Post09-04-2004, 11:26    Subject: Alternator Failure After Engine Wash A3 ALH? Quote
I'll try to find out something about that number if I have the chance.
Translated on 01-10-2026, 11:55.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alternator Problems? Get Fast Repair! Diesel Engine Technology
No new posts Light machine faulty? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Alternator Repair: Faulty Field Winding? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Engine wash Diesel Engine Technology
