knubbi Guest
10-04-2004, 7:47 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Hello!
I've been reading around in this forum for a while and haven't found the solution to my problem here either.
I have a question for the experts:
I have an A6 with a 1600cc engine. 160000 km. The car is running perfectly. So far, there have been no problems.
However, for the past six months, I've been experiencing the following problem:
One can drive with the car at full throttle for 1 hour without any problems (if one wants to), but as soon as one then (when it is running properly) takes their foot off the gas and tries to accelerate again, the whole car vibrates and several cylinders fail. (I estimate three)
There is no entry in the error memory. The injectors are new because the error 'Needle position sensor short to positive' was recorded in the error memory. The error has now been deleted, but the problem persists.
The mass flow meter is also new.
I'm now betting on the pump. But I don't really think it's a mechanical failure. I'm more inclined to think it's the pump control unit.
Has anyone experienced this problem before???
Does anyone have spare parts for such a pump?
Knubbi
knubbi Guest
11-04-2004, 5:53 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...]...hat echt keiner eine Idee???
Hat jemand schon mal das Pumpensteuergerät ersetzt?
Mein Audi Händler sagt : Pumpe ersetzen. (schlappe 1900€ im Tausch)
Hab gestern nochmal sicherheitshalber die Stromaufnahme der elektrischen Benzinpumpe gemessen. Die ist aber auch ok.
Was noch auffallend ist: Wenn der heisse Motor lange im Leelauf läuft laufen die Adaptionswerte der Laufruheregelung der linken Zylinderbank gegen -2 bis -2.5 mg/H. Die Zylinder der rechten Bank liegen um 0. Der Motor läuft jedoch schön rund.
Bin echt ratlos.... |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
11-04-2004, 10:06 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...] Hi,
also die VP 44 hat meines Wissens nur ein Magnetventil mit dem der Einspritzvorgang gesteuert wird und das sollte auch nur eine Treiberendstufe in der Elektronik haben.
Beim Aussetzen einzelner Zylinder halte ich ein Elektronikproblem der ESP für unwahrscheinlich.
Eventuell wird wo was zu heiß, so daß Dampfblasen im Kraftstoff entstehen?
Oder es wird irgendwie Luft in die ESP angesaugt...
Grüße, Rainer |
Profile PM WWW Garage |
knubbi Guest
11-04-2004, 10:10 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...]...ah, wenigstens mal eine Info.
Wenn Luft angesaugt wird musses ja auch irgendwo undicht sein. Ich kann nichts finden.
Gruss Knubbi |
matthiasTDI96 Profi-Schrauber
11-04-2004, 10:53 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...] Luft kann auch durch kleinste Schäden an porösen Dichtungen eingesaugt werden, die noch zu klein sind um Diesel durchzulassen. Das mit der Luft im System wäre sicher eine denkbare Lösung. Die von Rainer angesprochene Dampfblasenbildung halte ich hingegen für noch wahrscheinlicher. Hast du irgendwie die Dieselleitungen anders verlegt? Eine neue Abdeckung verbaut? Auch wenn du es für unwahrscheinlich hältst, ich hatte mal einen 60PS Polo mit AEX Maschine, der hatte mir nie ärger gemacht. Das einzige Problem bestande einmal als ich von Olpe ( Sauerland ) so gegen 2 Uhr nachts nach Flensburg gefahren bin. Da da alles frei war bin ich die ganze Zeit fast ausschließlich vollgas gefahren. In Flensburg ging dann an der ersten Ampel nichts mehr und ich dachte das ding hätte es hinter sich. Da war aber so eine Bullenhitze unter der Motorhaube als ich die öffnete das ich mir erhoffte, das da nur der Sprit zu heiß geworden ist, da die Zuleitung ganz dicht im Windschatten hinter dem Motor verlief. Halbe Stunde gewartet und alles war wieder bestens.
Gut damals war es Hochsommer......weiß nicht ob das auch bei den momentanen Temperaturen auftreten würde......
Also versuch mal in die Richtung zu sucen |
knubbi Guest
11-04-2004, 10:58 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...]Das Auto ist absolut serienmässig.
Ich werde trotzdem mal die Motorabdeckung nachher runter machen und mal schauen, ob mir da was auffällt.
Dann werd ich nachher auch mal mit dem VAG Tester auf die BAB und ein Auge auf die Kraftstofftemperatur werfen.
Das scheint aber kein generelles Problem zu sein, sonst würde ja was in der ELSA stehen. |
knubbi Guest
11-04-2004, 13:24 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...]...jetzt weiss ich etwas mehr:
Ich war gerade 180 km mit VAG Com auf der BAB und der Fehler trat nicht auf!
(Die Kraftstofftemperatur pendelt sich so allmählich bei 50°C ein, wenn man schnell fährt, wobei VAG Com den Kanal mit 'kraftstofftemperatur-Umgebungstemperatur' benennt. Das würde bedeuten, dass es tatsächlich 62°C waren)
Der einzige Unterschied zu sonst ist, dass der Tank randvoll war.
Somit scheint es ein Kraftstoffversorgungsproblem zu sein. Ich tippe nun auf die Saugstrahlpumpe im Tank, die den Kraftstoff von dem einen Teil des Behälters in den anderen pumpt. (ich hatte vergessen zu sagen, dass es ein Quattro ist)
Hat jemand mit dieser Pumpe schon mal Ärger gehabt? |
11-04-2004, 13:35 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...] Das ist eine in der Tat sehr mögliche Erklärung. Habe leider weder Quattro noch 4motion. Denke aber, das du den Fehler selber auschließen kannst wenn du die Rückbank ( oder halt irgendwo am Kofferaumboden bei einem Kombi die Abdekungen zu den Pumpen und Mengengebern im Tank entfernst, die Pumpe ausfindig machst und dir mal anschaust ob sie angesteuer wird ( Multimeter ) und dann nicht funktioniert.....ansonsten weiß ich da auch nicht weiter! |
knubbi Guest
11-04-2004, 13:39 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...]Ja, werd ich machen sobald der Tank leer ist.
Trotzdem danke, dass Du mitgedacht hast.
Sobald ich weiss, ob das der Fehler war werde ich berichten.
Gruss Knubbi
P.S.: Frohe Ostern |
11-04-2004, 22:42 Subject: Hard nut! AKE, cylinder missing after BAB ride! |
Translating... |
[Translating...] Beim V6 gabs IMHO mal was mit den Leckölleitungen (Gummischläuche).
Such mal in der Fehlerdatenbank, da steht dazu was drin.
Grüße, Rainer |
