Tire Size Adjustment for VW T4
bitsch1m
Post09-03-2004, 19:45    Subject: Tire Size Adjustment for VW T4 Quote
I would like to fit tires on my T4, 1999, TDI 75kW, where the circumference is 7% larger.
They will pass the TÜV inspection, but a speedometer adjustment is required!
My question is whether this can't be set in the vehicle's control unit, since I was able to
I went to the VAG workshop, and they said that it couldn't be done, that they couldn't make the change.
It would be great if someone of you could help me.
Hi Michael
onclebenz
Karma: +0 / -2   Thank you, like it!
1987 Mercedes-Benz SL Class
Post11-04-2004, 16:30    Subject: Re: Adjusting Tire Size on VW T4 Subject: Re: Adjusting Tire Size on VW T4 Hi, I'm looking to adjust the tire size on my VW T4. I'm considering going with 225/55R16 tires. Are there any known issues or problems with this size? Thanks, [Your Name] Quote
Hi Michael
Yes Hello!
Okay, hier ist die Übersetzung des Textes, wobei alle exakt beibehalten werden:
"Please provide the text you want me to translate from German to English. I will ensure that all are kept exactly as they are in the original German text. I will only provide the translation, without any explanations."
Best regards, Unclebenz
Karma: +807 / -0   Thank you, like it!
Post12-04-2004, 11:13    Subject: Tire Size Adjustment for VW T4 Quote
"Why don't you look it up?"
*impulse count
Don't forget the asterisks. Success/Failure Reports Requested icon_smile.gif
Hello, Rainer
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB BKD: Engine Control Unit Tuning/Remapping On-Board Diagnostics (OBD)
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts Engine Control Unit Tuning Problems On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. VCDS: Adjusting Ash Mass for Optimal Performance Diesel Engine Technology
